4wd idiot light
Old Oct 16, 2012 | 12:59 PM
luvdiesel's Avatar
Red face
Justin & Slacker
Sounds like you guys may have a slightly different problem.
Keep in mind, it takes a special reader to be able to see trouble codes from the transfer case control module and possibly the transmission control module as well.
As a side note, I can still shift the transfer case and use 4wd if I get into a pinch. I removed the shift motor leave it off most of the time. I can then climb under the truck and rotate the shaft with a cressent wrench. Takes a little playing around to figure out which position is which but it works.
Old Oct 16, 2012 | 01:11 PM
slacker 24/7's Avatar
Originally Posted by luvdiesel
Justin & Slacker
quite possibly, i think my issue is simply a engagement light deal , with the manual shift lever in my '07 the transfer case has always shifted in and out fine, light just doesnt always work..which i believe is the "switch" on top of the transfer case, so maybe we are talking apples and oranges with manual shift and electric shift ??
Old Oct 16, 2012 | 08:55 PM
jhenson's Avatar
Well, I listened to the shift motor this morning and it's going into 4hi and back to 2wd with no problem......it just won't go into 4lo.....obviously this is a shift motor problem for me??
p0wd3rp1l0t
Jun 27, 2012 10:29 PM
***gyro***
Nov 16, 2004 02:16 PM
Barry Smith
Nov 14, 2004 09:56 PM
dakar
Jan 28, 2004 07:58 PM
MYTRNx3
Feb 28, 2003 01:20 PM
