48RE Tranny Question/Trouble
Old Sep 19, 2008 | 09:15 PM
HERC FE's Avatar
Yesterday I noticed my '03 (108,000 miles) was not downshifting into first gear at stoplights and I felt a little bump as I sat there...delayed downshift. It intermittenly did this a couple of more times on the way home from work and occasionally didn't shift down to first at all. I got home checked the fluid and cycled the gearshift and transfer case too, as I had used 4X4 earlier that day and everything seemed normal again...Hmmm??? Today I drove about 30 miles to work and the thing completely stopped downshifting to first gear...I'm starting out in second...All other shifts/gears are normal. I've read that this could be a pressure solonoid or pressure transducer problem? Or have I lost a band??? Any body got a clue as to what I'm looking at here?
Old Sep 19, 2008 | 10:42 PM
#2 only's Avatar
here are some possibilities:
1. Governor Circuit Electrical Fault. Test with DRBT scan tool and repair as
required.
2. Valve Body Malfunction. Remove, clean and inspect. Look for
sticking 1-2 shift valve, 2-3 shift valve,
governor plug or broken springs.
3. Front Servo Piston Cocked in
Bore. Inspect servo and repair as required.
4. Front Band Linkage Malfunction - Inspect linkage and look for bind in
linkage.
Old Sep 20, 2008 | 07:48 AM
jman's Avatar
Hi, mine trans was doing the same, took it in to the dealer, thay canged fluid, filter and adjusted the bands,, the guy who did the work told me the trans looked great, but the front band was realy out of adjustment,the trans shift great now, i belive better than before.
jman
Old Sep 20, 2008 | 07:50 AM
HERC FE's Avatar
Thanks for the reply #2...I guess my weekend will be trouble shooting this malf and hopefully getting the ol girl back in running shape
Old Sep 20, 2008 | 07:55 AM
HERC FE's Avatar
jman
I was thinking it might be the band too...they have been adjusted previously by the dealership, but it's hard these days to get something done right unless you do it yourself.
Old Sep 20, 2008 | 09:26 AM
#2 only's Avatar
HERC FE, how many miles on the tranny, and do you have mods?
Old Sep 20, 2008 | 12:41 PM
HERC FE's Avatar
No Mods...stock drivetrain...this morning the tranny is operating in first gear again...but I am getting the little ocassional bump after I stop as it delays downshifting. Could this problem be temperature related as the fluid has cooled down??? Anyway, I have decided to drop it off at the dealership and have them look at it on Monday. I'll weigh in on what they have to say and then figure out what I'm going to do.
Old Sep 22, 2008 | 09:55 AM
HERC FE's Avatar
Unhappy Bad Valve Body
Looks like I have a bad valve body..
Old Nov 5, 2008 | 07:33 PM
phatboy's Avatar
I am having the same problem...when I stop i get a small surge. Dis the VB solve the problem? How much did the charge you?
Old Nov 24, 2008 | 08:16 AM
pete42's Avatar
Smile same problem
haveing same problem and truck surging up down please let me know pete.
ridlangus123
Dec 30, 2013 08:36 PM
TKC2000
May 24, 2012 10:42 PM
2500Ram
May 18, 2010 12:55 PM
workingdog
Feb 21, 2008 07:04 PM
termite
Jul 14, 2005 09:04 AM
