48RE Question?
Old Oct 23, 2007 | 08:48 AM
ntnbolt1's Avatar
48RE Question?
If you drove this tranny (in a new 5.9) just like a car (ie) no mods, no trailering, 80% interstate driving, no heavy pedal and perform the regular scheduled maint. Could you go 200k with out any problems?
Old Oct 23, 2007 | 08:51 AM
vzdude's Avatar
DTR's 'Go to Guy'
I have 153K on mine now, with added power for the last 50K - no problems! Keep the fluid and filter changed.
Old Oct 23, 2007 | 09:10 AM
J BODY's Avatar
I swapped a unit out of an 04 hotshot rig that had 414K on it. Only reason he lost it was that the output speed sensor had been leaking pretty bad and he ran it low on fluid and welded the intermediate shaft to the OD piston retainer.
Old Oct 23, 2007 | 10:17 AM
new2ctd's Avatar
I have 145k on mine towing 24k trailers all the time.
I did put in a DTT valve body at 130k because I wanted to fix the crazy shifting. No other work.
Old Oct 23, 2007 | 01:28 PM
Almond Pale Ale's Avatar
just do the routine maintenance and it should be solid for that long.
Old Oct 23, 2007 | 01:44 PM
RowJ's Avatar
I'm not a synthetic nut...but I do believe Synthetic AFT does extend the life of a factory tranny by better lubricating it during those time when tranny temps do get above 200*.
As said above, do the maintenance, with a tendency towards overkill, and you will get 200,000 out of it. Especially with 80% Hwy miles. I would expect more!
RJ
CTDCAL
Sep 27, 2003 03:22 PM
dansdad
Sep 6, 2003 09:00 PM
Sittenbull2
May 30, 2003 11:16 PM
Sittenbull2
May 15, 2003 04:15 AM
malibu
Feb 5, 2003 08:22 AM
