48RE...No power transfer in any gear
Hi all. Not sure whether to be ****** off or not. Seems like the trans died, but did so after a long trip, right outside my doorstep. Almost anyway; It's parked across the street.
I have a 2003 HO 4x4 3500 dually, bone stock.
Really weird symptoms. Stopped and prepared to back up into my long downhill driveway with the 5th wheel on, and the truck simply wouldn't move. The engine revved but there was no power to the wheels.
It bumped a couple of times like it was going to lock into reverse and move, then nothing. In any gear.
I checked the electrical connectors, the shift linkage, the throttle linkage, and the transfer case linkage in case there was an obvious failure. I had been travelling over bumpy logging roads with the 5th. There was nothing amiss.
I have to check trans fluid level, but it's never been an issue before.
Any ideas what might be going on here?
Thanks,
Chay
Thanks,
Chay
Is yours an automatic with 4wd? I just had to replace transfer case because front seal in xfer case blew out and all of the tranny fluid in it pushed into the transmission causing it to be over full. I did not experience tranny failure, but it could be the cause of the overfill in the tranny.
Gary
Gary
Yes it's 4x4. Interesting!
It could be an input shaft. What is weird though is that this occurred at a very low torque. I was just shifting to get ready to back up the trailer.
Also interesting is that the engine revs absolutely clean...no grinding or sound of any kind.
Chay
Chay
Well, I pulled the trans pan and it had lots of metal in it.
There was even a small flat piece of metal down there. Maybe a piece of band or steel ring? Not sure.
The transfer case was full, and the colour of the fluid was different so I don't think that's my issue.
I'm taking it to a local trans place, will have them install Goerend parts.
I think the worst part will be waiting for shipping!
Chay
Chay
8mpg
May 22, 2006 01:35 PM
trout74
Aug 29, 2005 06:25 PM
Lightman
16
Jan 21, 2004 10:46 PM
