48RE band adjustment
Old Oct 31, 2008 | 09:49 AM
bigD-megacab07's Avatar
I had my 07 5.9 in the shop a couple of weeks ago and I asked the service advisor if band adjustment was part of the 30k transmission check and change of fluid. He said that not "all" 48 RE's had band adjustment. Any validity to this statement? As I have said in the past, I do not like or that matter trust dealerships reference actually fixing problems.
Old Oct 31, 2008 | 10:31 AM
Pooter's Avatar
Yes, they all have bands that can be adjusted, he probably just didnt want to do it.
You might not need to, if they trans is still shifting ok and you arent towing too heavy, id wait till 60k-90k if everything is still shifting fine...
Old Oct 31, 2008 | 11:44 AM
alboy's Avatar
I called my dealership, they said no they adjust automatically,your service manual says to adj at 30-35 k,i guess they don,t have access to one,so just wing it.I did it myself,not a big deal,trans now shifts awesome.
Old Nov 1, 2008 | 07:59 PM
SS1156's Avatar
I am interested in this too. My 03 shifts too soft. I was wondering how to make the shifts a lot firmer. I will be doing a TC, VB and billet input shaft in the future. I was looking for something I could do now to firm up the shifts.
booman70's Avatar
If you already had it serviced I would leave it till the next service unless you are having problems.
Old Nov 1, 2008 | 08:12 PM
jughead's Avatar
unless a lot has changed the front of the od trans is basically the same from 1962 on. if one snugs the band and then backs it off 1.5 to 2 turns there will never be a problem with sec. gear band until it wears out. i built them for 40 years even raced them for a few and that worked for me.
Old Nov 1, 2008 | 08:15 PM
SS1156's Avatar
Mine has 60k on it and the only thing I have done is a fluid change. How would I go about having the band adjusted? Will this improve the shifting?
Old Nov 2, 2008 | 02:21 PM
booman70's Avatar
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
RDR
81
Aug 26, 2009 03:07 PM
michael_b8
Nov 2, 2008 12:20 PM
modiesel
21
Sep 26, 2008 11:09 AM
ArXane
Sep 2, 2007 01:03 PM
betsycam
Sep 26, 2004 03:44 AM
