48RE Band Adjustment Bolt Sizes
Old Oct 31, 2008 | 10:28 AM
michael_b8's Avatar
Hey Ya'll,
Trying to make sure I have the right tools to make the band adjustments. Last thing I want to happen, is to drop the pan and find out I don't have the right tools.
Anybody know if the following correct?
Rear band Locknut 9/16"
Rear band Adjustment Screw 1/4" Hex
Front Band Adjustment Locknut 3/4"
Front Band Adjustment Screw 5/16" Square Male
One other question. Is it really important that the locknuts be tightened to the specified torque?
Thanks guys,
Michael
Old Oct 31, 2008 | 11:57 AM
alboy's Avatar
I think you need a torx head # 20 or 25, it should be posted on here,torque to 72 inch pounds,also i used a red marker pen so you can tell that you have backed off 3 turns after tightning it.
Old Oct 31, 2008 | 01:30 PM
SOhappy's Avatar
The lock nuts, probably not critical. But you need a torque wrench to set the band adj. screws anyway, so you might as well use it for both (although one is in ft-lbs and the other in in-lbs if I remember correctly- may need two torque wrenches). I'd do it just to be safe.
Also, you should have a new filter and 7 qts of ATF+4 for ATF in pan only or ~17 qts if doing the complete exchange.
Old Oct 31, 2008 | 09:14 PM
OOPS's Avatar
I thought all the hardware on these were Metric sizes, did I think wrong?
Old Nov 1, 2008 | 07:56 PM
booman70's Avatar
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Old Nov 2, 2008 | 12:20 PM
Shagginwagon's Avatar
Thanks Boo! Good info.
FordTrax
Apr 18, 2014 08:47 PM
RDR
81
Aug 26, 2009 03:07 PM
modiesel
21
Sep 26, 2008 11:09 AM
ArXane
Sep 2, 2007 01:03 PM
betsycam
Sep 26, 2004 03:44 AM
