MAP Sensor question
Old Dec 1, 2006 | 01:14 AM
Cam73's Avatar
MAP Sensor question
Can anyone tell me what the 4th wire on the MAP sensor is for? I'm in the process of retro-fitting a common rail MAP sensor for use with a quadzilla commander in my 97. Not sure where to get a good +5 volts let alone what the 4th wire does.
Thanks
Old Dec 1, 2006 | 07:19 AM
MikeyB's Avatar
The MAP connector has two 5v leads. One is 5v power (Light Blue) from the ECM and the other is the 5v feed (Dark Green/Orange) to the Rail Pressure Sensor.
MikeyB
Old Dec 2, 2006 | 02:32 PM
Cam73's Avatar
Thanks!!
I think I'll supply the MAP with take +5v from the water temp sensor.
Old Dec 20, 2006 | 01:55 PM
nickleinonen's Avatar
4 wires...
1. 5vdc common
2. return common [ground]
3. 0.5vdc-4.5vdc ecm return for manifold pressure [boost]
4. 0.5vdc-4.5vdc ecm return for manifold air temprature
not sure what the pin order or color is without a wiring schematic
Old Dec 20, 2006 | 01:57 PM
dodgezilla04's Avatar
the red is the 5vdc power wire. dark blue for boost, light blue for temp
Old Dec 21, 2006 | 12:59 AM
Smkndzl's Avatar
You cant just take 5 volts from the coolant temp sensor , it is a analog resistive circuit, that 5 volts supply has a resistor in the ecm along with the A/D reciever , your coolant temp would never read right again.
Old Nov 2, 2008 | 12:45 PM
Cam73's Avatar
Any ideas how to make it work?
It's been 2 years of waiting for the analog to digital boost sender from Quad so I'm pretty sure it's not going to happen...
scottboy69358
Jul 4, 2013 02:05 AM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
