48 RE service-WOW
Old Sep 20, 2008 | 07:57 PM
alboy's Avatar
48 RE service-WOW
Serviced the trans on my 06,changed the filter ,adj the front and rear clutches as per JOES instr.THANKS JOE!.Only 35000 miles on the truck ,with fairly heavy towing,should i do it or not.Phoned the dealer,said they are all computerized,don,nt need any adj,hmmmmm!!! Guys this thing shifts like it never did ,even from new.There is no pause at all between shifts,as before,i would have,to let off before it would shift,now it just hauls on level 3,very very smooth!I WAS AMAZED AT THE AMOUNT OF ADJ,thought i was doing something wrong,it finally got to the 72 lbs per inch.If your trans is not shifting properly this may be an area to look at.The tranny fluid was still in good cond.tHE INFO IS GREAT ,THANKS GUYS.
Old Sep 20, 2008 | 07:58 PM
ian515's Avatar
is there a link to joes instructions that I missed? I wouldnt mind givin that a shot.
Old Sep 20, 2008 | 08:22 PM
RowJ's Avatar
Originally Posted by alboy
....The tranny fluid was still in good cond.
Did not reuse it...I hope.
How do you know how good it is?
RJ
Old Sep 20, 2008 | 08:43 PM
alboy's Avatar
Gone to recycling,still a bright red ,no burnt smell,had the little Lady check it,she said its okay,i,m not one to argue.ian515 , highly rec doing it, not difficult at all,look under servicing your 48re,takes approx 7 litres ,this is filter and pan only,about 15-16litres if you do the torque converter,i did only the aforementionedand will suck out another 8litres and add next month,rather than drop the pan,the improvement is unbelievable.
Old Sep 21, 2008 | 05:57 PM
dozer12216's Avatar
Glad you got great results. Now for the bad news. Remember the adjustment on outside you made. Tighten screw down to 72 in# and back off X turns and lock jam nut. When threads no longer protude beyond jam nut, the KD or second gear band is WORN OUT. Futher driving will only make expense of repairing greater. For your information and reference. JMHO
Old Sep 21, 2008 | 07:15 PM
alboy's Avatar
Thanks for the heads up,still some room left,i was shocked how much they both took,man does it shift nice!When the adj runs out i,ll replace it with a NADP HEAVY HAULER TRANS.
rbrettctd
Nov 11, 2008 01:42 PM
roadgeneral
Oct 17, 2007 06:54 PM
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
getblown5.9
Dec 18, 2005 08:28 PM
