47RE or 48RE ??
Old Apr 26, 2010 | 09:49 PM
Ram Guy's Avatar
47RE or 48RE ??
Yes I have searched...
I have an '03 SO not HO with a production date of 10/02. My shift lever says OD on/off not tow mode. Every sign in the world points to my truck definatly having an 47RE (SO,early '03,OD on/off). EXCEPT, after reading on the pacbrake website according to my equipment ID tag in the glovebox, it is a 48RE. The other thing that kinda throws a wrench into the identification is that the dealer installed a new trany before I bought the truck. Is it possible that they did NOT replace it with the same as what came out?
I want to put in a Transgo kit but I know the 48RE and 47RE kits are NOT interchangable. I also know that the two tranys are identical physically on the outside. So...How do I find out for sure what I have?
Old Apr 27, 2010 | 12:21 AM
Nate-03 D's Avatar
I 've got a 2003 SO build date says 03/03. Tag in the glove box says (DG8, If I remember correctly, thats the code for a 48re).
Even our old 2003 SO with the same build date of 03/03 had the 48re in it.
I don't think the OD on/off button indicates it's a 47re. I may be mistaken though. Our 04.5 says OD on/off.
Old Apr 27, 2010 | 07:07 AM
no_6_oh_no's Avatar
The 48RE went into production Jan 03, except for a very few trucks that were already in process at the christmas break, 01-03 and newer is a 48RE in all SO and HO configurations.
The 48RE also has two configurations for the VB, the early VB uses the same shift kit as a 47RE. Its the later transmissions, generally 05 and newer, that use the different kit.
Since the dealer replaced the trans it is possible they put a 48RE in there. On one of the pan rails should be a part # stamped into the metal. Thats about the only way you can look up the trans type without doing some dissassembly.
Old Apr 27, 2010 | 10:34 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
About the only fool proof way to tell is get inside the front clutch drum. If it's a 48RE it will have 7 clutches and 5 steel plates. If it has 5 clutches and 3 steel plates it would be the 47RE. I have the 03 also and mine was a 05-03 model build and the sticker said 48RE. I didnt know for sure until I bought parts for the trans and found out it had a 47 in it. No big deal. I bought the drum, clutches, and steels for a 48RE and put her back together... along with a few other parts I toasted. LoL
Old Apr 27, 2010 | 11:12 AM
no_6_oh_no's Avatar
Stock 48RE has 4 frictions in both the direct and forward clutch packs. The only way you get more than that is a custom build.
05-03 build had a 48RE from the factory, no other options as the 47 was out of productuion. If you really had a 47RE it was swapped in.
Easier way to tell is look at the input shaft. The 48RE has an o-ring on the end and a heavier stepped input.
Old Apr 27, 2010 | 12:49 PM
ropnjessi's Avatar
I believe on the VIN number if the 8th digit from left to right is a "number" its a 47RE, if the 8th digit from left to right is the letter "C" it is a 48RE.
thehemikid
Feb 25, 2021 12:45 PM
Munchies
Oct 19, 2006 06:09 AM
RAMMANX2
31
Mar 5, 2003 09:55 AM
paward
Jan 31, 2003 04:04 PM
FireNhole
Dec 7, 2002 04:39 PM
