About to hit 50k
Old Apr 26, 2010 | 08:24 AM
singleturnout's Avatar
About to hit 50k
I want to switch to a synthetic oil but stuck between Amsoil and Royal Purple, could you guys please share your thoughts on the pros and cons.
Every fluid in the truck is getting changed out
Many thanks Aaron
Old Apr 26, 2010 | 12:53 PM
anybody
Old Apr 26, 2010 | 05:04 PM
Lost Lake's Avatar
Well you're not switching because of the miles you pound on your truck.
All the oils are the same. Use a good filter and change your oil regularly. Especially with those low miles.
Old Apr 27, 2010 | 09:05 AM
sturgeon's Avatar
I agree with Lost Lake, change your filter when you should, add oil, run the crap out of it. if you intend on trying Royal Purple run the math first, if your going to run each oil change three times longer because the oil is advertised to be the best, take note, whatever kind of oil you run, the engine is going to produce crud (particulate matter)to put in your filter regardless what oil happens to be in the motor. the good ole fashioned "change your oil at factory reccomendations" is pretty spot on.
Old Apr 27, 2010 | 02:45 PM
Boris-MC1's Avatar
I have first hand experience with RP, it is a top of the line oil.
This 5.9 is not oil sensitive. Any good quality oil will do as long as it meets or exceeds Dodges recommendations.
Good luck.
B
Old Apr 27, 2010 | 05:40 PM
tlloyd's Avatar
Your not thinking with your Dipstick,,JIMMY..
Trooperthorn
Jun 9, 2014 10:53 PM
DodgeCTD
22
Jun 21, 2008 09:39 AM
Billm2004
38
May 15, 2008 06:24 PM
rednose
Jun 5, 2005 11:55 AM
ViperSBT
Nov 1, 2004 06:30 PM
