4 wheel low poroblem
truck goes in 4wheel high back to 2 wheel just fine but will not go into 4wheel low light blinks but does not engage.I think it may be a problem electronic sensor if so where would it be located.
I am going to assume you are verifying it by driving and not just the light.
It could be the actuator is binding or there is an issue internally with the t-case.
Had the same problem on a 08 2500 last summer. Had found the toyo mt that i had on the truck had wore different due to air bags in the back. The problem started after rotating the tires. I replaced the tires and the problem went away.
rjm022
13
Jun 9, 2023 06:34 PM
