ISB in other than Ram
Old Feb 14, 2011 | 01:00 PM
imsven's Avatar
I know that this seems off the wall, but I was wondering if anyone out there has experience with using a 6BT, or better yet an ISB in a construction equip application? I have an old Fiat-Allis 10B bulldozer with a bad engine. Can't seem to find a used engine and would like to adapt in a Cummins ISB. My pick up truck experience VS the dozer tells me that it would be a lot easer to start and probably have a little more power. I think throttle control would be better also.
Thanks
Old Feb 14, 2011 | 01:37 PM
HMX-1's Avatar
I thought that construction/gen-sets were what Cummins built the first 6BT's for back in the early 80's.
Other than getting it to bolt up to the tranny, I don't see why it wouldn't work.
Kris
Old Feb 14, 2011 | 01:52 PM
imsven's Avatar
construction 6BT
It is true, that is how the 6Bt started out. It was, I believe, a joint project between Cummins and Case. What I am looking for is the adapter info to make it work.
Old Feb 14, 2011 | 09:44 PM
Backwoods Bumpers's Avatar
Vendor - Former Vendor
If you can sort out the wiring and electrical part, then go for it. I used to be a mechanic at a Komatsu Equipment dealership. They had 4 and 6 cylinder cummins for the last 15 or 20 years at least. They've used the 12v setup and the 5.9 and 6.7 Common rail. Keep the engine adapter from the machine and bolt it up to the back of the cummins. I can't think of any reason why it wouldn't work, but then I've never done it!
dieselfuelonly
Jan 26, 2007 11:11 PM
4doogie
Dec 7, 2006 08:05 PM
possum
May 24, 2005 11:30 AM
james satterfie
Sep 13, 2004 03:52 PM
Shaders 24v
Nov 7, 2003 04:14 PM
