35x12.5/16 will the rub?
Old Apr 22, 2008 | 08:51 PM
dodgemaniac's Avatar
35x12.5/16 will it rub?
i was thinking on putting a set of toyo open country m/t 35x12.5/16 of my truck.
i was wondering if these tires would rub and if so what could i do to fix the proablem? also would these tires fit on my stock rims or would i need new rims too?
also should add that suspention is stock
Old Apr 22, 2008 | 08:53 PM
Dodge89W250's Avatar
stock rims are 17 so they would not fit
Old Apr 22, 2008 | 08:56 PM
04smoker's Avatar
Uh. Stock wheels are 17's. And if youi have a way to SAFELY put 16's on a 3rd gen than let us know! I have several buddies that put 16.5's on their trucks, but only after much grinding of the brake caliper.
mine are 16 or at least i think they are? even if it is 17in rim would it work with a 35x12.5/17
Old Apr 22, 2008 | 10:54 PM
bradler's Avatar
I don't think they would work with a stock truck. Guys with a 2in leveling kit have been able to fit the MT 35x12.50, but i have heard of a few rubbing the back of the front wheel well when turning while suspension is cycling (only on one side, drivers i think, because the leveling kit pulls the axle off center). I have seen 33's on a stock truck, looked like a good fit...
Old Apr 22, 2008 | 11:04 PM
DC/LT's Avatar
Mine are ok
I just put 315's BFG ATs on my 06 4WD that is stock. They rub very, very little. I have a full replacement bumper on the front, gives more forward clearance, if stock, I think you may have to trim. I know for a fact with the 2" leveling kit you will clear it.
Old Apr 23, 2008 | 08:48 AM
enafzige's Avatar
35x12.50x17's will work on a stock truck with stock wheels with minor rub on both control arms at full lock.
--Eric
Old Apr 23, 2008 | 04:04 PM
3500eh's Avatar
with 2 inch level kit very little rub
Old Apr 23, 2008 | 05:20 PM
Dieseljunkie's Avatar
--Eric
Yep, been doing that for a while with my truck.. Works fine as long as you don't get carried away with locking the wheel when you turn.
Old Apr 23, 2008 | 05:24 PM
ddestruel's Avatar
From: Used to be missoula, montana: Now in Sonoma County California
you can fit 16's on a 3rd gen IF you install 02-00 caliper brackets and smaller rotors. your caliper will work on the earlier brackets. caliper brackets are about $59+/-
Ive got 315/75 R17's on my 03 3500 and i have 0 rub thats with aftermarket wheels. with stock wheels i had slight rub at full lock. very slight. stock wheels worked well with the 315's
Old Apr 23, 2008 | 05:31 PM
Also are my stock rims wide enough to accomidate 35/12.5/17r ????
Old Apr 24, 2008 | 08:16 AM
HotRodK's Avatar
Smile
Yes they are.
Old Apr 24, 2008 | 08:36 AM
tcr's Avatar
tcr
Not if you listen to the tire mfg. But everybody does it. They are too narrow and will bow out the center of the 12.5" tire. Remember tread width might only be 10" or so, but total tire width is 12" or so.
Old Apr 24, 2008 | 08:42 AM
tcr's Avatar
tcr
315/70RR17
Load Index 121 = 3267lbs (1485kg) per tire
Load Index 118 = 2982lbs ( 1355kg) per tire
Speed Rating “R” = 106mph (170kph) 121/118R D Not Rated For Severe Snow
3195 lbs.
50 psi
17/32"
64 lbs. 8.5-10"
8.5" Min rim width
12" Total tire width
NA
34.5"
601
06Cummins
95
Dec 16, 2006 04:20 PM
06Cummins
Oct 25, 2006 10:23 PM
DirtEater
Nov 2, 2005 11:35 PM
anestech*
May 26, 2004 08:52 AM
Sarge1124
Dec 30, 2003 02:59 PM
