342 gear set behind 48RE
Old Nov 16, 2007 | 07:59 PM
Mike M's Avatar
Would like to know if anyone has put the high gears behing the Automatic, and how it works out.
Old Nov 16, 2007 | 09:52 PM
Raspy's Avatar
I can't answer your question directly, but I can say that I have 3.73s with 285/75/17s and the gearing is a bit high for heavy towing. First is slow to move out and OD is only good for slight grades or the EGT and locomotive roar really come on strong. Stock tires and the 3.42s might be good though. Or bigger tires and no towing.
John
Old Nov 16, 2007 | 10:08 PM
raychem's Avatar
I have been running a set for a while now....I LOVE THEM. My truck is 4x2 and for me crusing at 2500 rpm @ 85 w/3.73 was too high;. I cruise @ 2175 now @ 85 mph and have picked up about .6 mpg. For your truck though....19.5" wheels with 4.10 I would go 3.73. The 3.42 would be a bit too tall for you.
Richard
Old Nov 17, 2007 | 07:10 AM
MikeyB's Avatar
I don't think 3.42's with a auto is a good mix if planning to tow.
I had 3.42's on my Chevy pickup and absolutely hated it for towing. Would always downshift on a slight grade and even during a headwind.
MikeyB
Old Nov 17, 2007 | 11:36 AM
Mike M's Avatar
Thanks for your imput, the 19.5 tires are 32 inches tall and only added about 3mph at 65. Don't tow often and when I do its a 5k boat and rarely a travel trailer of about the same weight. Used to pull a 14k 5th wheel with it and the 4.10 were great. Want better economy, only geat about 11.5 in town and about 13 highway.
Old Nov 19, 2007 | 12:08 PM
tonyiii1's Avatar
I had 3.73s with 35" tires and hated the gearing (I think it makes it around 3.20 or 3.30). No torque for pulling passes or hills. I put in 4.10's to get back to stock ratio's and it is great. I don't run around at 85 though.
I also had 3.42's in a chevy tahoe and hated it. It ALWAYS was down shifting.
Old Nov 19, 2007 | 02:36 PM
Rednecktastic's Avatar
You should find someone with 3.73 gears that needs 4.10s and swap them.
I need to do this like tony ^ said you loose some umph with 35's and 3.73 gears.
My combo is basically like running 3.42 gears on the stock sized tires. I bet it wouldn't be too bad if my 35 inch rolling stock wasn't so heavy.
Old Nov 19, 2007 | 05:17 PM
Mike M's Avatar
Maybe someone in Northern Cal or Reno, NV needs 4.10 and wants to swap there 3.73, need front & rear
supersonictoys
Oct 24, 2009 03:08 PM
cminzey
Jun 24, 2008 09:17 AM
trout74
Aug 29, 2005 06:25 PM
Patrick Campbell
Oct 19, 2003 09:22 AM
