34 days GOT IT BACK! and still WHINES!!
Old Dec 11, 2003 | 09:13 AM
moss2904's Avatar
Re:34 days GOT IT BACK! and still WHINES!!
I think in Texas three repairs for the same problem and no resolution to the problem, you have a lemon.
I would check the law in Arizona about how it works there.
Randy
Old Dec 11, 2003 | 10:09 AM
BADodge2003's Avatar
I fully understand your trouble with the dealer. I have been fighting an uphill battle with mine over a recent hack job to my interior by a contracted glass tech. > For starters, they should have put you in a loner until you have gotten your truck back in the shape that it is suppose to be in (BRAND NEW). Second Lemon laws are pretty standerd 3 strikes and your out. I would seriously consider a new truck. Once your on that downhill slide, sometimes there is no getting back up. Does your truck have lmt slip rear? When it came time for me to service my diffs. I had a question about addative for the lmt slip rear and the guy said that I had to add it. Obvioulsy this contradicted what the mannual says so I posted it up here and found that no addative was required, and damages could result if it were to be used. I would check that the dealer didn't mistakenly put addative in the rear diff. thinking it was a dana rear end. It is quite clear to me that several dealerships don't have as qualified personel as they lead you to believe. That is why my confidence in dealership service and quality of work has little to be desired.
Old Dec 11, 2003 | 04:06 PM
propinc's Avatar
I hated to post this but when I got the truck back with the "New Rear End" still whines. and Dodge knows of the problems but has no fix to date
My Notes when I spoke to: AA&M (American Axle) the people that made the Rear End. admits there is a problem with the Dodge 3500 2X4 140.5 wheelbase with he 5.9 Cummins seems that there is a whine coming from the rear end and they are trying to work a fix for the problem. He seems to think that that the drive shaft has a 85 Hertz Dampener on it now creating a harmonic noise through the truck. His suggestion was to try the "new" 385 Hertz dampener it's not known if this will work for sure either but it is worth a try he thinks?
I also believe that is why Dodge is not offering the 3.73 Ratio's in the 2004 until they have the problem solved for sure ........ huummmm who designes this stuff??
I would like to know if "anyone" out there has a Non whining 3.73 Ratio in a 4X2 140.5 wheelbase 5.9 ?? BTW it starts at about 60mph
Old Jan 25, 2004 | 10:54 PM
DodgemnLeavem's Avatar
Re: Re:34 days GOT IT BACK! and still WHINES!!
Originally posted by SuperGewl
Take it back and have them prove it to you and if that doesn't work out then tell them to BUY the truck back or give you a nother one ;D Hi all Seems were not the only ones with the 3.73 11.5 rear ends with probs.... I just had my 15000 mile service done today. actual miles were 14888 on the clock. well other than the most annoying noise from the rear end of this thing this truck is a dream. its awesome but im really ****** about the rear end noise it started at about 1200 miles and really has gotten worse SO when the tech at my local jiffy lube took the magplug out of the rear diff it was coverd in shavings and the oil ORIGINAL oil mind you was BLACK even smells burnt. wife says it looks charcoal grey with a silvery tint to it thats the metal in it. the tech stopped and gave me a paper coffe cup with the oil sampl and then whiped the plug of on a paper towel. he said take this to your dealer. I took one look at it and I was HOT there were no svc departments open as its sunday here, But tomorrow Im going on a ramping bi@#hing party with them. I told one dealer already that there was a noise from the rear but they said." we drove it and can find no noise or any abnormality. your probly hearing the resonance from the exhaust" can you belive that load!! Ill post tomorrow what i find Im getting a new rear or there buying this thing back not paying 40,000 for crap like this.at only 15,000 miles.
NotEnufGarage
Feb 10, 2010 12:04 AM
boaterman
Oct 15, 2008 10:44 AM
apache
Oct 3, 2005 10:27 AM
JoshPeters
Apr 3, 2005 08:13 AM
