3 micron drop in fuel filter?
Old Dec 11, 2010 | 07:07 AM
dshind's Avatar
Maybe I'm way behind on stuff , but I just found out that AFE makes a 3 micron fuel filter that goes in the canister on our trucks.their part #44-FF10 and sells anywhere from 21-29 dollars depending on where you buy it.Anyone else heard of this?
Dave
Old Dec 11, 2010 | 07:45 AM
dezeldog's Avatar
Is this filter a water separater as well??
Jim
Old Dec 11, 2010 | 08:00 AM
Shorts's Avatar
I've read from others who've spoke directly to AFE, it is only a fuel filter, not a water separator
dshind's Avatar
afe
Not sure ...went to afe site,they just talk about filtration on the description of the filter.It would about have to be tho wouldn't it?
Old Dec 11, 2010 | 08:32 AM
MikeyB's Avatar
The AFE filter is not a water separator.
Best bet is to use the Baldwin PF7977 fuel filter. Best filtration and a water separator.
MikeyB
Old Dec 11, 2010 | 10:07 AM
92'1stGen's Avatar
Not to mention I believe the AFE filter is only rated 3 micron nominal and not absolute.
Old Dec 11, 2010 | 12:26 PM
CoastalDav's Avatar
MikeyB
I've been using the Baldwin fuel filter. There is a differance in the color of the filter compared to the stock filters I've used in the past. I've been meaning to post some pics of the two side by side. The stock filter is tan in color after 10000 miles and the Baldwin is a light shade of black. No hunks of stuff just a much darker color than the stock filter. Most of the fuel was pre-filtered before it ever got to the Trucks primary filter from the rear aux tank equipped with a Racor Rotary type water seperator filter with a 10 micron filter in it.
Dave
Old Dec 11, 2010 | 12:32 PM
KKB's Avatar
KKB
Where do you guys get the Baldwin filter?
Old Dec 11, 2010 | 12:44 PM
Dr.Dizzle's Avatar
Enter your zipcode to locate a dealer near you.
http://www.baldwinfilter.com/
Old Dec 11, 2010 | 02:02 PM
Diesel Newbie's Avatar
If you have a Grainger near you, they carry them.
Old Dec 11, 2010 | 06:23 PM
Danderson's Avatar
www.blinefilter.com.
Old Dec 12, 2010 | 08:22 AM
MikeyB's Avatar
Dave
Dave,
The dark material are asphaltenes that is caught by the filter. Since the Baldwin has a lower (better) micron rating it's doing better job of trapping the particles.
MikeyB
Old Dec 13, 2010 | 09:55 AM
CoastalDav's Avatar
Dave,
MikeyB
That was my point. Big difference if you ask me between the two filters. Did not know what the black stuff was. Ran 619 gallons thru that Baldwin. The previous filter had 677 gallons run thru it. It was Tan in color as metioned above.
Thanks
Dave
Old Dec 13, 2010 | 10:17 AM
AH64ID's Avatar
The AFE is 7um absolute, 3um nominal and not a f/w separator.. As its been said the Baldwin PF7977 is the best available.
1985cucv
Mar 28, 2009 09:49 AM
03RAM2500
Jan 11, 2009 05:21 PM
Treangen
Feb 22, 2007 02:21 PM
tweeter
Apr 13, 2006 10:54 PM
Chillimau
Jun 16, 2004 07:10 AM
