3.73 OR 4.10 How do I know?
Old Sep 24, 2009 | 12:36 AM
Clane's Avatar
One way to determine the axle ratio is to raise one rear wheel and with the tire valve stem pointed toward the ground and a mark on the driveshaft. Turn the wheel one complete revolution and count the number of times the driveshaft turns. More than 4 turns - 4.10; less than 4 turns - 3.73
Limited slip you while have to raise both rear tires.
L8r,........dogger
Will that work with any size tire or only stock size?
Old Sep 24, 2009 | 08:32 PM
billie's Avatar
^^ if you're not kidding, yes any size. One revolution is one revolution
Old Sep 25, 2009 | 01:19 AM
Clane's Avatar
wouldnt a smaller wheel would take less to complete a revolution then a larger wheel??...
Thinking of it as gears where the small gear takes twice as many turns to complete a revolution as the larger one....???
Old Sep 25, 2009 | 10:35 AM
randallp84's Avatar
OK, a smaller tire will cover less ground in one revolution than a larger tire will, yes. However, one revolution is always 360 degrees, no matter what size tire you have. You're comparing revolutions to revolutions here, not the distance traveled after one revolution. Think of a wristwatch versus a clock tower. One revolution of the big hand is one hour, doesn't matter what size the clock is. Make sense?
Old Sep 25, 2009 | 11:34 AM
Clane's Avatar
Yes it does. Thank You.
Old Sep 25, 2009 | 04:49 PM
billie's Avatar
I wasn't trying to be smart but I've been bit by the "practical joker" in the past.
bglz42
Apr 7, 2007 07:30 PM
sakisaki400
Apr 5, 2007 11:08 PM
Jezzhuntin
Oct 13, 2006 06:34 PM
PurNLoud
Sep 8, 2006 11:40 PM
JKM
Jul 3, 2005 04:59 PM
