3.73 OR 4.10 How do I know?
Is there an easy way to figure out which gear ratio I have in my truck VIN numbering?
I figure it has to be either a 3.73 or 4.10 At about 62mph the tach says 1900 |
I'm 3.73 for sure, stock tires, etc... here's my RPM's
45mph - 1400rpm 55mph - 1550rpm 60mph - 1700rpm 65mph - 1800rpm 70mph - 1950rpm |
I am pretty sure it is on a sticker in the glovebox.
If you have a 6 speed then you have 3.73's, it's the only ratio available w/ the G56 in 06'. The G56 is naturally geared much, much lower than the previous manual offerings.
Wow
Thanks for the quick response!!! 3.73 I'm good with that... Side note I suppose I should have said... the tires are 265/70/17 No sticker inside the glove box.. I guessing long gone. |
Axle ratio
One way to determine the axle ratio is to raise one rear wheel and with the tire valve stem pointed toward the ground and a mark on the driveshaft. Turn the wheel one complete revolution and count the number of times the driveshaft turns. More than 4 turns - 4.10; less than 4 turns - 3.73
Limited slip you while have to raise both rear tires. L8r,........dogger |
There is a sticker in the glove box that will have that information. If not call a dodge dealer and give them the VIN.
Amazing how such a simple topic can bring out childish behavior in some people.
(Post 2585341)
Originally Posted by randallp84
(Post 2585406)
???? I don't think any of the posts exhibited childsih behavior, unless you deleted one...
(Post 2585418)
I didn't delete one....I deleted 10 of them [yuk]
(Post 2585341)
(Post 2585418)
(Post 2585418)
I bought a Ford once that had 3.73s or 4.11s installed. I had no intention of towing and had them swap axles with a different truck on their lot for 3.55s. I doubt it was ever updated in Ford's database and certainly not any of the stickers on the truck. To be 100% certain count the revs like dogger writes.
