3.08 Gears in Rear End
Old Oct 7, 2008 | 09:23 AM
johnr9q's Avatar
Does anyone know if I can get a higher rear end gear (lower number) for my 2007 than 3.42? I would like a 3.08 if possible. I checked with the vendors awhile back and nothing was available.
Old Oct 7, 2008 | 05:32 PM
levigarrett76's Avatar
nothing higher than 3.42 available
Old Oct 7, 2008 | 11:43 PM
BroncoHound's Avatar
I don't think you would want anything taller than a 3.42, especially with your "newer" G56 gearing. I have the same gears/transmission in my '08 and, at 63mph, I am at 1600rpm. 1600rpm is about the lowest you can go at cruising speed and still get good mileage (i am assuming you want the tallest gears you can in order to maximize highway fuel economy). Any lower than 1600rpm and the MPG drops.
Old Oct 8, 2008 | 07:14 AM
MikeyB's Avatar
Adding 285/75/17 with 3.42's will get you close, 3.17.
MikeyB
Old Oct 8, 2008 | 12:09 PM
BPoulsen's Avatar
MikeyB -
How do you calculate that? I'd like to know what mine is with my 3.73 and 325/60/20's.
Thanks in advance
B
Old Oct 9, 2008 | 12:10 PM
MikeyB's Avatar
Originally Posted by BPoulsen
MikeyB -
Thanks in advance
B
I created an excel spreadsheet with the formulas.
The 325/60/20 is roughly 35.3" tall (depending on the manufacturer) so your new ratio is 3.31
MikeyB
Old Oct 9, 2008 | 07:35 PM
Utundra's Avatar
MikeyB -
Thanks in advance
B
Try this, http://www.1010tires.com/TireSizeCal...bmit&reset=yes
Then enter the diameter data in this, http://4lo.com/calc/geartire.htm
Quick search couldn't find one that does it all.
Old Oct 18, 2008 | 10:35 AM
johnr9q's Avatar
My desire is to get the best MPG. I could go with taller tires but the problem is they are also fatter and more rubber on the road and more sidewall to flex which reduces MPG. So I'd like to stay with the original tire and reduce RPM with gearing. I've looked into the overdrive units but doubt I'd recoup the cost of $3000.
Old Oct 19, 2008 | 11:04 AM
HotRodK's Avatar
Thumbs up
On a 4x4 it takes quite a while to recoup all the money for 2 gear swaps. On a 2wd, obviously it would take 1/2 the time. I would love to drop back from my 4.10s to a 3.42, but I just cant take the jump. It would take a very long time for the money to add up for a 1-2 even maybe a 3mpg gain. In town I would expect my mileage to actually drop with the 3.42s as it take more power to move those gears vs the 4.10s...
Its a slippery slope for most of us.
doorguy
Jun 8, 2007 06:19 AM
93beater
Feb 28, 2007 09:28 AM
ouchman
Apr 16, 2006 03:26 PM
badmrb
May 27, 2005 05:48 PM
13
Mar 29, 2003 11:46 AM
