271 D Transfer case leak
Old Mar 13, 2014 | 09:52 AM
Cody Carter's Avatar
I just bought my 2004 RAM 2500 a couple weeks ago with 160K miles on it. I thought it was a good deal even with a few expected leaks. But this one baffles me. I have tracked my transfer case leak to the fill plug. The plug threads look good. I torqued it the the specs, yet it still dribbles. I suspect it was overfilled. At a significant decline the ATF was level with the bottom of the fill hole. I thought there's no way it could have filled that full without stand the truck on it grille to fill it, especially with it leaking.
Last night I read in other forums that ATF could be transferring from the transmission to the transfer case. Is this possible or likely? I haven't checked the transmission fluid level since I bought it. I will do that tonight.
What would cause enough pressure for the ATF to push past the fill plug?
Thanks,
Cody
Old Mar 14, 2014 | 06:23 PM
kloppk's Avatar
The tcase has a vent tube to allow for thermal expansion.
If the vent is plugged it could cause the fluid to push past the plug.
I believe there is usually a washer with the plug to help seal it.
farmer0_1
Sep 30, 2006 12:52 AM
Bobcat698
26
Aug 1, 2006 11:38 AM
Bobcat698
17
Jul 18, 2006 07:54 PM
realsquash
Nov 7, 2005 12:44 PM
Checkmate
Apr 25, 2005 09:20 PM
