2100 rpm vibs getting bad
Old Dec 15, 2003 | 11:24 AM
  #46
BamBam's Avatar
Re:2100 rpm vibs getting bad
Does anyone have a copy of the TSB?? Or know where we can get one??
Old Dec 15, 2003 | 03:37 PM
  #47
johnshole's Avatar
It is TSB 19-008-03. The fiw is a new ps hose from the pump to the hydroboost.
Old Dec 20, 2003 | 03:55 PM
  #48
100 Proof's Avatar
From: Eagle, Idaho. Please set your watch back 20 years when entering.
You can find a copy of the TSB here:
http://dodgeram.info/tsb/2003/19-008-03.htm
100 Proof
Old Dec 21, 2003 | 08:25 AM
  #49
LRAmberson's Avatar
I got the dreaded vibe :'( ,I believe the remedy will be a larger harmonic dampener... I am going to contact American Axle to see if they plan to sell this 385 mghz dampener to the general public..
Old Dec 23, 2003 | 09:16 AM
  #50
bluerattler's Avatar
sound like a good idea but why should we have to pay for this it fixes the vibe? I'm willing to try anything but dodge can pick up the tab, right? Let us know what you find LRAmberson & good luck
Old Dec 23, 2003 | 02:52 PM
  #51
cma1day's Avatar
harmonic dampner is a new one on me....more info please...and im glad someone is suggusting something new to try......but i better not say anything more, ill get sent to the bad chair.........thanks
Old Dec 26, 2003 | 08:57 AM
  #52
cma1day's Avatar
anyone hrd anymore on the harmonic dampener?????
Old Dec 26, 2003 | 09:02 AM
  #53
jthorpe's Avatar
DTR Founder
Re: Re:2100 rpm vibs getting bad
If you don't act like you you did in the last thread, you'll be fine.
Old Dec 26, 2003 | 12:35 PM
  #54
bironside's Avatar
I wonder if it is just in the HO, I have an 2003 SO with no, knock on wood, vibe. Just a thought.
Old Dec 26, 2003 | 07:02 PM
  #55
MonkeyLips's Avatar
I'm getting a harmonic drone, not really vibration, between 2000 and 2200 (68-75mph) in 4th gear. It's getting worse as the miles add up. It didn't start until I had about 1k on the ticker; now approaching 5K. I can hardly stand to drive between 2,000 and 2,200 rpm in OD. At 2,300 rpm or 80mph, it's gone, so I try to avoid 70 to 75mph on the interstate, otherwise I get a headache. Other than trying the dealer, which I'll do this week, any suggestions?
Old Dec 27, 2003 | 08:20 AM
  #56
you're in the club monkeylips-- that's the vibe-- and for bironside, yes it is in the '03 SO-- only difference is mine is a shortbox-------- and if I hear that it's in the driveline one more time.....
Old Dec 27, 2003 | 08:26 AM
  #57
cma1day's Avatar
THANK YOU BLUERATTLER!!!!!!!! IM WITH YOU ....
Old Dec 30, 2003 | 05:53 PM
  #58
smiller's Avatar
FWIW I had a (or should I say 'the') slight but very noticeable vibration in the steering wheel at 2100 rpm (about 70 mph in 6th) which got worse when the A/C compressor started, in other words... the usual (vehicle is a '03 2500 HO CTD). Sometimes I could hardly notice it and sometimes it practically put my hand to sleep unless I sped up/slowed down to get out of the trouble area. Had the new ps/hydroboost hose installed per the TSB and it was very effective in my case, essentially eliminating the problem. Much more pleasant to drive on the freeway now. Looking at where the weight is on the hose (in the middle on the rubber line, not on any of the hard points) I can't imagine why it makes the difference that it does, or how DC ever figured this fix out, but at least it worked (for me). Give it a try even if you are skeptical, only takes about 30 minutes and at least it can't hurt...
Old Dec 31, 2003 | 10:12 AM
  #59
RankRam's Avatar
smiller: Same results here, I'm very happy with the results.
RockcrawlingTJ
May 20, 2007 02:16 PM
morkable
37
Sep 21, 2006 07:14 PM
big red psd cc
Feb 3, 2005 04:25 PM
cma1day
36
Dec 21, 2004 07:48 AM
Strjock81
Sep 23, 2004 01:53 PM
