2007 Spicer Axle U Joint???
Old Aug 21, 2009 | 04:25 PM
dodgediesel's Avatar
Question 2007 Spicer Axle U Joint???
Hi guys. What is the best Spicer U joint to run these days for the AAM fron axle?? Whats better, greasable or non greasable. I got 2 new ones installed at Kal Tire a year ago and the one is shot. It is a greasable one. Thanks for any help or opinions.
Old Aug 22, 2009 | 04:45 PM
Anyone?????
Old Aug 22, 2009 | 05:20 PM
RiverRat2's Avatar
only lasted one year???? that seems like a short time period,,,,,,
Makes me wonder if it was installed correctly or perhaps you got a bad one???
I've had good Luck with greasable Spicers in other 4wd applications (Chevy's Fords, Jeeps, Dodge trucks,, All Gas trucks,,,,,)
Old Aug 22, 2009 | 05:22 PM
surfram's Avatar
I just had precision 464 greasable axle u-joints put in my truck. The stockers lasted 97,000 miles.
Old Aug 22, 2009 | 08:23 PM
mini14's Avatar
if u dont grease them they will fail,,,,also make sure the stub axle isnt all snoted up from taken out the old one.
Old Aug 23, 2009 | 12:45 AM
Ramified5.9's Avatar
Yea buddy, I just replaced mine and used my ball joint press to remove the OEM ones (138xxx miles). I did a good job of slightly bending the yokes, (did not realize it until I installed the new joints and could not get the half circle clip in and what a PITA to hammer them true again!
Next time I am going to use heat. Then after they are apart, heat them again and dip them in used oil.
I also used Precision greasable U-joints. Found out that NAPA wants $97 each and O-Riely (AKA Checker) only wanted $48 for the same dang part #.
Old Aug 23, 2009 | 01:50 PM
I grease my front end every oil change. The other side is tight?? Just wondering what the part number is on the greasable Spicers or should a guy go with the Spicer for life non greasable ones??
Old Aug 23, 2009 | 09:29 PM
kokalit's Avatar
Summit racing has the greaseable Precision 464s $35 each.
http://www.summitracing.com/parts/PC...Engine+Type|L6
Old Aug 24, 2009 | 07:24 AM
MassZJ's Avatar
Greasable ones are good if someone remembers to greases them. They are weaker than the solid non greasable ones though.
underwoodbits
Jul 1, 2009 03:49 PM
sawboywv1
Mar 24, 2006 02:58 PM
Hummin Cummins
Aug 7, 2005 06:46 PM
Dodgeboy440
Sep 25, 2003 03:29 PM
