2007 - 2500 SRW to DRW
Old Mar 2, 2010 | 08:44 AM
Silverstreak's Avatar
Looking at the conversion for my truck listed below. I know I need the duallie hubs for the front axle and need to swap out the rear differential for a 3500 duallie. But on the rear bed, can I just add the factory duallie fender extensions to my existing short bed, like on the mega cab duallies?
Old Mar 2, 2010 | 10:22 AM
Lost Lake's Avatar
You need to do a search! There are a couple guys on here looking to go the opposite way, and you could swap parts with them at no cost I bet.
One guy is even getting rid of his dually box for a flat bed. Good luck!!!
Old Mar 2, 2010 | 01:05 PM
SpeedyWS6's Avatar
I don't think you have to swap the whole diff... You just need the DRW hubs if I remember right. Doing this you end up with the rear being about an inch narrower than a factory drw truck but as long as there is not tire rub you should be fine.
Old Mar 2, 2010 | 11:49 PM
Colo~Dirtbikers's Avatar
A new dually rear diff is needed. Dually hubs wont work unless mated to dually diff.
Old Mar 3, 2010 | 07:28 AM
SpeedyWS6's Avatar
Yeah I was thinking wrong. Your right.
Old Mar 3, 2010 | 08:01 AM
nwflyoda's Avatar
you can use your rear end but you will need the dually brake calipers, axle shafts as well as hub/bearings. pretty much, everything from the end of the axle tube out for the rear end to be switched over. i was thinking about converting mine over as well but i've had a hard time finding someone to swap parts in my area and plus i really don't need a drw...i just wanted it more for the stablility while towing.
MikeRP
79
Nov 21, 2016 10:19 PM
lawdog800
19
Mar 31, 2011 09:26 AM
89dieselkong
Apr 5, 2009 05:20 PM
dragginlx
15
Mar 9, 2007 11:32 AM
DodgeBob
Jan 10, 2003 03:07 PM
