2006-up A/C Compressor Replacement
Old May 2, 2020 | 08:32 PM
Tobin's Avatar
Has anyone with a 2006-up replaced the cheaply made A/C compressor with a different style compressor. I am looking at replacing it with either of the two:
  • Sanden SD7H15 like on the 03-05 trucks and use the 03-05 suction and discharge lines - 9.46 cubic inch displacement
  • Seltec TM16 that looks about like it will bolt up, might just have to bend the lines a tad. Seltec TM16 If you open the spec sheet there is a direct mount (looks to have same mounting pattern) 8 rib version with GM pad style mount for the lines that seems to measure the same as what is on the truck - It has a 10 cubic inch displacement
Any other option for a stock replacement that will actually last?
Thanks,
Tobin
Old May 22, 2020 | 03:53 PM
TJAR66's Avatar
I went with stock when my compressor came apart.
Old May 30, 2020 | 10:13 AM
rockcrawler304's Avatar
I also went with the stock style. No issues in 2 years so far
1972RedNeck
Jan 30, 2020 09:46 AM
1$Chuck
Jul 17, 2011 02:21 PM
gadget.35-06
Jun 2, 2011 01:54 PM
Txwelder
Jan 25, 2008 04:15 PM
DmaxEter
Nov 13, 2005 01:38 AM
