2006 Engine Temp ???????
Old Feb 27, 2017 | 06:08 PM
rbertalotto's Avatar
Maybe you folks can help......
I have a 2006 Dodge 2500 with Diesel / Automatic. Pulling a 20' Toy Hauler about 6,000 pounds
My engine temperature is running around 205-210......going up a hill it might reach 215...Ambient temp is 70 degrees here in Texas today.
Traveling interstates at 67 mph / 1800 RPM
Without trailer temp hovers around 198-200
Is this normal?
Old Feb 28, 2017 | 05:27 PM
shep1's Avatar
Slight temp increase pulling uphill should be O.K. as long as it's not getting close to the hot mark. Does it go down on the downhill side? I would think 15-20 degrees wouldn't cause a problem, (I'm no expert), as long it returns to normal going downhill or on the flat. I see a slight increase in mine going up I-70 from Denver into the mountains when the ambient air temps are in the 60-80's even when not pulling my 8500# trailer. Is the fluid level O.K.?
Old Mar 1, 2017 | 07:38 PM
Yes, goes back down quite rapidly on the downhill side.
Brand new radiator, waterpump and thermostat.
Guess everything is OK.....Only 2100 miles and I'll be back home!
MossyOakCTD
19
Dec 28, 2010 09:11 PM
jrussell
17
Sep 17, 2007 06:38 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
DanTana
Mar 6, 2006 05:56 AM
firesine
Nov 24, 2005 10:58 AM
