2006 ctd 2500 steering rattle
Just curious i am having problems with what i consider to be a rattle coming thru the steering column and the foot pedals. Its not when i hit bumps its all the time if feels like another piece of metal hitting the column and transferring enery. Anyone with this kinda of problem ????? dealer says they cant find anything wrong??
2006 DODGE 2500 4X4 CTD SWB, w/Timbrens
2007 Sandpiper 315bht Triple slide Fifthwheel
WIFE, KIDS, AND CHOCOLATE LAB HERSHEY
Easy now!!! The arms are very solid. This problem noise is common with a good number of stock truck owners to so dont give me that! Myself and others just want to figure out what it really is. Someone else had the same problem and it turned out to be a bad axle u-joint needle bearing.
Having a working knowledge on link suspension on Rockcrawlers I know that if they have to be set up. If the link angles are not right on, it can do some weird thing and make some strange noises.
sorry guys just got back ......no lift kit it is a stock truck never changed anything. it has 23 thousand miles on it.... the timbrens are great for towing they stay off the axle when not towing and work great with a load no bouncing or jerking with my fifth wheel,...
its more of an anoying feeling in the wheel almost like the steering colunm is loose but the dealer says they dont feel it go figure... i have had four other people drive it who say they can feel it plain as day......im lost
mine had same noise-plus, my entire front end is new! replaced everything this past june. it turns out it is my steering shaft. have a buddy grab the shaft (with the hood up), while you turn the steering wheel- see if he can feel the "pop" and movement of the shaft- if he can-you need to replace it!
i also tapped the shaft portion that goes inot the steering box(at the bottom linked to the steering rod) and it had a little rattle in that also the dealer has its head in its ***......driving me totally nuts.........
did you confirm it to be steering box causing the rattle?
just wanted to give a heads up ...the dealership is saying they are going to replace my front left axle.....that there is a place to lube this axle at each oil change....news to me so i will see when i get it out of the shop..
