2004.5 Rough Idle Question
Old Jul 12, 2010 | 09:36 PM
spye's Avatar
My 04.5 started idling rough today and it seems to miss just a bit right off idle. It has plenty of power and only produces black smoke when I get on it with zero hint of whote smoke anywhere. Just having the problems at idle. I replaced the lift pump about 50K miles ago with an airdog and replaced the filters just a little while ago. I also checked the oil just tonight and has not risen and does not smell like diesel. Truck has 162K miles and has original injectors and no power adders.
Should I just run some cleaner through it? I dont really want to have to replace injectors but am willing if I have to. Any suggestions are appreciated.
Old Jul 12, 2010 | 10:17 PM
White Ghost's Avatar
it sounds like you have an injector going bad. mine has done the same a few times. good luck
Old Aug 24, 2010 | 11:34 PM
highwayman's Avatar
I had same problem with same truck-was a nightmare at170k--Dealer wanted 8k+ to fix an could not even tell me what was wrong with it -diagnosed in drive way (with great help from DTR)wound up #4-5-6 inj. bad purchased at diesel shop from Bosch @370.$ each 120k later an rollin
powerrammaster
Nov 4, 2011 04:52 PM
banks twinram
May 18, 2010 08:10 PM
etdrag
Dec 4, 2005 05:08 AM
donhov
Sep 23, 2005 10:40 PM
Mexstan
Mar 31, 2003 02:37 PM
