Rough Idle Question
Old Nov 28, 2005 | 11:07 PM
etdrag's Avatar
Rough Idle Question
1999 Automatic, 156K Only mods are 4" exhaust, K&N air filter and rebuilt tranny. Lift pump pressure is fine, fuel filter has been changed, truck idles really bad rough. Once you put the truck in gear it smooths out, drives fine no power loss of fuel economy loss. No codes found, I have killed each injector using a test feature on scanner every time you kill one injector the idle definalty gets worse. I am lost please give me some advice. Under a idle or deceleration mode is the only time you notice the Miss.
Thanks David
Old Nov 29, 2005 | 03:39 AM
TerryS's Avatar
I have been dealing with the same thing for a year It slowly gets worse sorry to say I tried all the easy stuff , APP reset , IAT. MAP. new injectors. just ordered a new Vp44 $1100 bucks . low pressure at idle will not pop off the injectors is the cause.
Old Nov 29, 2005 | 10:33 PM
mrschendel's Avatar
Check the EPS
Old Dec 4, 2005 | 05:08 AM
TerryS's Avatar
New VP44 pump fixed it! started right up no more miss,less smoke. idles at 825 now.I will see if I get my fuel mileage back with the new pump!old pump made it 82.000 miles.
spye
Aug 24, 2010 11:34 PM
banks twinram
May 18, 2010 08:10 PM
Haulin_in_Dixie
Oct 23, 2005 10:04 PM
TheMoose
Sep 20, 2003 07:44 PM
Mexstan
Mar 31, 2003 02:37 PM
