2003 Truck Purchase
Old Mar 30, 2005 | 10:56 AM
cjperry's Avatar
2003 Truck Purchase
Would an automatic truck delivered to GA in March of 2003 have a HO or SO? Thanks for your help.
Old Mar 30, 2005 | 11:15 AM
HOUTEX's Avatar
S.O. MOST LIKELY. HO WAS 6 SPEED TILL VERY LATE 03 EARLY 04 I THINK.
Old Mar 30, 2005 | 11:42 AM
Bluedeviltorque's Avatar
Either Way
Could be either S.O. or H.O.. And it could have 47re or 48re respetively. You'll have to pop the hood to find out for 100% sure. But with that early 2003 delivery date, I would be more willing to gamble on it being a S.O..
I have a 2003 with H.O. and 48re. There are tons of 03 H.O.'s up here in CT it seems and hardly any S.O. trucks. Why, I'm just not sure.
Mike
Old Mar 30, 2005 | 11:53 AM
cjperry's Avatar
Thanks, is there any way to tell from the VIN? I am supposed to pick the truck up on Friday, but when I looked at it earlier in the week I did not check the engine tag. It seems like March would be a late year build? If they swap model production in June or July, then wouldn't March be at least 1/2 way through the production year, so is it still considered an early model? Thanks for your help!
Old Mar 30, 2005 | 12:11 PM
bluebull's Avatar
There is a tag on the engine that will tell you what the Hp rating is. HO is 305 for 03 build.
Old Mar 30, 2005 | 03:16 PM
bubba33's Avatar
You can tell by the vin# call it in to a dealer.Mine is a HO auto 48RE built in june.I know 2 guys with SO built in march they have the 48RE,and they could of ordered the HO but chose not too.You could end up with a 235-250-305 HP in that truck.It should be a 48RE in there.
Old Mar 30, 2005 | 04:44 PM
Mike_Boutet's Avatar
The 8th digit of the vin is the engine code. The HO is a C. I'm not sure what the SO is.
Old Mar 30, 2005 | 05:23 PM
HorseHauler's Avatar
if it was built march of 03 it will deffinately have the 48re in it, they started the 48re on Jan 1, 2003. but you will just have to check on the HO/SO question
Old Mar 30, 2005 | 06:08 PM
Locomotion's Avatar
Darn, all these model-year overlaps can get confusing!
But HorseHauler is correct.
Old Mar 31, 2005 | 08:27 AM
cjperry's Avatar
Thanks for the help. The 8th digit in the VIN is a "C" so it sounds like a 305 truck. I call to teh owner seems to confirm this information. I am also excited to learn that the truck has the 48RE. Thanks for all of the help.
Old Mar 31, 2005 | 02:13 PM
bigblock2stroke's Avatar
all 305/555 autos have the 48RE, but not all trucks with 48RE are 305/555.
Old Mar 31, 2005 | 07:23 PM
jnck's Avatar
POSITION INTERPRETATION CODE = DESCRIPTION
8 Engine K = 3.7L 6 cyl. MPI Gasoline
N = 4.7L 8 cyl. MPI Gasoline
D = 5.7L 8 cyl. SMPI Gasoline
6 = 5.9L 6 cyl. Turbo Diesel
C = 5.9L 6 cyl. Turbo Diesel High Output
W = 8.0L 10 cyl. MPI Gasoline
Z = 5.9L 8 cyl. SMPI Gasoline Light Duty
Straight from service Manual for 8th digit
Old Apr 1, 2005 | 07:58 AM
pcburnout's Avatar
8th digit SO being G
Mine is SO (Super Output)
Thank God it has a 48re which DTT said was not shipped in SO models must of been last of SO's.
bierk76
16
Oct 13, 2006 08:27 AM
dawall
Jan 3, 2004 09:29 PM
needlern32724
Nov 9, 2003 04:57 PM
FarmDiesel
Sep 12, 2003 09:25 PM
shortround
Aug 22, 2003 02:50 PM
