2003 idles up, why?
Old Apr 8, 2007 | 09:59 AM
nkh95's Avatar
2003 idles up, why?
I recently purchased a 2003 2500 5.9LHO. It seems to idle up when I come to a stop sometimes and won't idle back down unless I really press the brake hard. Any thoughts? I'm new to these, my last truck was a 99 powerstroke.
Thanks,
Nick
Old Apr 8, 2007 | 10:15 AM
rjm022's Avatar
what do mean when you come to a stop?? a traffic light? or when you put the truck in park? what is the temp outside when this happens?? these trucks have a high idle feature that will kick the rpm's up to 1000-if the outside temp is cold enough (when the truck is in park) to cancel this, you depress the brake pedal.
Old Apr 8, 2007 | 10:20 AM
MAN's Avatar
MAN
My 03 will idles up when it cold out and I don't have my foot on the brake. All I have to do is tap the brake or the fuel and it will idle down.
Old Apr 8, 2007 | 11:37 AM
Buffman88's Avatar
my 04.5 will do this also go up to around 900 then go back down to 750 when i am at a stop
Old Apr 9, 2007 | 05:19 PM
nkh95's Avatar
The best way to describe when it does it is when I drive up my driveway (uphill) in first gear with some gas pedal used. When I push in the clutch and step on the brake at the top it stays at around 1000 rpm. It won't idle down until I really mash the brake hard. It does it to in the morning when I back into my spot at work. Both times are after a 20+ minute drive on the highway so I don't think it's because it's cold outside. Thanks,
Nick
Old Apr 10, 2007 | 09:36 AM
Ryan Hyatt's Avatar
Do you have stock exhaust, and a big programmer, my buddies 03, auto did the same thing when he had a bully dog and stock exhaust but we straight piped it and it stopped.
Old Apr 10, 2007 | 06:31 PM
nkh95's Avatar
Nope, 4" from where the muffler was back, no chip at all and it's a stick.
Nick
Old Apr 11, 2007 | 09:34 PM
ctdnoypi's Avatar
Same issue was discussed at TDR and it was fixed by replacing a defective connector block that goes into ECM as the pins were not sized properly.The problem was also tied to erratic cooling fan operations and door lock issue.
sgrooms
21
Apr 8, 2008 11:17 AM
F. Flack
18
Aug 10, 2004 06:03 PM
gedjan
Feb 2, 2004 06:14 AM
linetrash75
Jan 28, 2004 03:09 AM
70DUSTER
Jun 26, 2003 11:31 AM
