2003 HO with 6 spd
Maybe be time for a fluid change. How many miles do you have on the truck?
Also the clutch could be dragging. Try pumping the clutch pedal very quickly about 5 times and see if it makes a difference.
MikeyB
MikeyB
It does shift ok when warmed up. I'll try pumping the clutch also. I have 113000 miles on truck and I had planned to have both the rear end and transmission oil changed next week.
Thanks guys for your help. Art
Mine can also be difficult to get into any gear after idling in neutral. It started acting that way shortly after switching to Redline. I'm not sure if the Redline is the source of the problem, but I'm thinking of switching to syntec to see if that helps.
mxmike27
Nov 5, 2009 03:00 PM
