2003 have ac ploblem?please
Old Aug 14, 2008 | 06:25 PM
lma's Avatar
lma
Arrow 2003 have ac ploblem?please
I have dodge 2003 ,3500 laramie . AC not working from last week. Blower is working good. Ac light comes on. no cool air . warm air is coming. I checked ac fuse and ac relay ,they are ok. I am not hearing compressor clicking on when I turn ac on. Can it be compressor problem? can anyone help me . thanks a lot.
Old Aug 14, 2008 | 07:33 PM
jpajax's Avatar
There is safety switch that will not let the compressor come on when there is no referent in system.
Old Aug 14, 2008 | 08:13 PM
Spooler's Avatar
More than likely it is low on refrigerent.
Old Aug 14, 2008 | 08:41 PM
lma's Avatar
lma
thanks for help. I got duracool Re-charge kit. I try after recharing. thanks again.
Old Aug 14, 2008 | 08:46 PM
Spooler's Avatar
Uh,,, You are supposed to charge the system to certain weight of refrigerent. Too much or too little will not work and too much will break things such as seal, evaps, and or condensors.
Old Aug 14, 2008 | 08:58 PM
lma's Avatar
lma
it says ,pressure must be beween 28psi to 38 psi. It says for all vehicle. how about this truck? how much pressure this truck recommend? thanks
Old Aug 14, 2008 | 09:39 PM
dozer12216's Avatar
The gauge on cans in store are junk. Good way to get in trouble or seriouslly hurt yourself. The low 134a level is sure indication of leak and adding more 134a will only be a temp fix. Don't continue to pollute by getting it permantlly fixed. Get a professional to repair. Would you attempt repair of your home A/C (?) unit.
Old Aug 14, 2008 | 11:55 PM
lma's Avatar
lma
last year I took my truck to Dealer for low refrigerent .They charged me $225 for it . they said , ac gas was too low and they refill it ,also checked for leaking. they said no leaking now.
Old Aug 15, 2008 | 10:49 AM
lma's Avatar
lma
thanks for help. I will take to dealers fix it.
Old Aug 24, 2008 | 03:40 PM
BLACKBEAR's Avatar
IF you will go out and by your self a set of good gages you can do it your self. Then you will have it to do it if you need them for a different gob--GOOD LUCK
Old Aug 25, 2008 | 11:47 AM
jpajax's Avatar
If you do it your self and do need to add be sure you put at least 2oz of ac oil in.
Old Aug 25, 2008 | 01:39 PM
Hayseed's Avatar
IMA just add the 134 slowly and you should be fine. Have the A/C on high/max and listen and watch for the compressor to kick on. I have done my own for years and I am a shade tree mechanic at best. Yes I would work on my house A/C as well. A/C is a really simple process of compression and evaporation. As many times as lightning struck around my house this spring I think it made more ozone than I could ever distroy. My 93 makes crazy high pressures unless the aftermarket electric fan is running so that is another source for losing your freon. The compressors have a relief valve that keep the systems from overpressure and if the condenser is not cooled properly the pressure can get high enough to bleed the freon out the relief valve. Get your low side pressure up to about 35 and see how it goes from there. Could be a leak that slowly bleeds the pressure, a major leak that won't let it keep pressure, or a faulty fan clutch that blows the freon out the relief valve.
If you smell a stinch coming from the vents then you will know the evaporator in the dash has a leak and is letting the freon come into the cab with the cool air. It really smells like old sneakers so you will have no problem diagnosing that one. Hope this helps but I would never take it to the dealer unless the last resort (evaporator). Those are a bear.
Old Sep 5, 2008 | 05:25 AM
BLACKBEAR's Avatar
IMA sounds like the dealer took you for a ride.That is way over charged!!
Old Sep 5, 2008 | 02:07 PM
BLACKBEAR's Avatar
Go to AC performance mod at this site it might help you out
Old Sep 5, 2008 | 04:25 PM
cumminshakesit's Avatar
i wouldn't take it to a dealer either... and yes i do work on my AC at home... i have a EPA universal cert. auto is easy, just like mentioned above, plug the can in, start engine, turn AC on, the suction side of the compressor will suck the 134a out of the can. if you over charge you will know it! the suction line going to the compressor will ice up! that is unevaporated refrigerant making its way to the compressor, (turning your comp. into a pump) it will be hard to do if the system is empty, it should take a whole can. you do not need to add oil. they will rape you at an AC shop or dealer, just cause they can... their leaktest method is either adding dye to the system, using a sniffer or simply looking for seeping oil on all the fittings... none of it is very effective. these days auto AC's are ony good for 7 years, give or take... then they will need recharged. your problem could also be the clutch, exhaust all other methods first, there is a low pressure switch to protect the compressor, so chances are you are out of juice. hit me up with any other questions. good luck blowin cold.
