2003 CTD with 47re tranny
Old Nov 12, 2008 | 12:37 AM
AlK's Avatar
AlK
Question 2003 CTD with 47re tranny
Pulled the transmission pan and changed the filter on the 47re tranny and found a piece of metal in the bottom of the pan. Looks like it is part of a snap ring. Any idea where that piece of metal comes from?
Also the transmission that does not shift properly into third gear, i.e. the transmission shifts normally into first and second, but shifts only momentarily into third and then into overdrive. Any ideas what is going on?
Thanks for your help.
Old Nov 12, 2008 | 12:52 AM
annabelle's Avatar
Prepare for a new tranny.
Old Nov 12, 2008 | 07:44 AM
no_6_oh_no's Avatar
Off hand, OD clutch retainer snap ring. Could be the reason for the fast shift to OD. Either way, time to pull the trans and go thru it before it totally grenades.
Old Nov 12, 2008 | 11:17 AM
Sasqoutch's Avatar
Dang, I had brass shavings in mine and decided it was time for a rebuild. With a piece of a snapring floating around in there id diffently pull the trans.
thehemikid
Feb 25, 2021 12:45 PM
2500
22
Jul 12, 2007 09:11 PM
Munchies
Oct 19, 2006 06:09 AM
cmckinney
Aug 13, 2003 10:14 AM
Mike67RS
Jul 24, 2003 06:59 PM
