2 Stroke Oil???
I have been running the 1 oz per gallon 2 cycle oil in my truck for the last 4 tanks of fuel. I have not noticed any MPG gains, no smoother running. I am sure it helps the internal parts out thoe. I just took a 1600 mile round trip with it and i was only getting 17mpg on the freeway at 80 mph.
What is wrong with adding synthetic 2cycle. I have been using it for 180000 kilometers (112000miles) I use a snowmobile oil in the winter because they claim it mixes better in cold weather. I have never had a fuel system problem with this vehicle. The original lift pump was still working when I replaced it with a Glacier 392. I have used it in a F--d 6.9 for over 200000mile with the crummy Stanadyne pump and it never had to be touched either. Who says you can't use synthetic 2cycle and what do they base it on. Remember there are those who say you can't use any 2cycle oil.
What do they know that I don't?
Jim O
Jim O
Nick
I use B-20. Which is 20% biodiesel I think. Someone please correct me if I am wrong. -------- Before I found the close to house B20, (same price as ULSD) I was using ashless TWC-3 from Wally world, pretty cheap buy the gallon, I used I qt to a tank. Someone said they thought that was a lot.
Actually it is only 1:1120- ergot; 32 ounces in 4480 ounces (using 35 gallons X 32 as my tank capacity) since 4 ounces to a gallon is 32:1 -- =128oz/gallon ---4480/4 = 1120 I think my math is correct but it is late,so someone tell me if it's not. Anyhoo, my point is 1 quart in a 35 gallon tank ain't overdoin' it. I've read or heard that biodiesel is EXCELLENT Lubricitywise. Even better than the plain old "low sulfur" -- before the ULTRA LSD. I don't plan on using anything else other than B20== Unless it gets very cold. Do any of you think I should use anything else besides B20? For other reasons I am unaware of ? I do realize that although Cummins says it is perfectly OK to use B20 Dodge Motors does not approve its use. (What does Cummis know, they only design and make the engine) Thanks.
nelrod, all I know is what I saw on the side of my truck and inside my motor which I posted pics of about a month ago. can only imagine what that much carbon would do to your cat. cummins recomends WAY less oil . the old lubricant in diesel fuel was sulfur which was measured in parts per million , not ounces per gallon. thats what you are replacing. if 1 qt per tank isnt burning cleanly and is building up as carbon in the combustion chamber, and through the entire exhaust than its obviously to much oil. a pint burns clean and still does the job and costs half as much with less polution
Super, thanks for info. I no longer use it, as I use B-20 now. I see your point, if a pint does job better, don't use any more than nedded. Also Super, FYI, the sulfur is NOT a lubricant. It is the PROCESS of removing the sulfur from from diesel oil, that cause some of the aromatics to be removed, which cause a lot less lubrication. It's what I read about it anyway.
Has anybody tried this stuff? http://www.fppf.com/lubricity100.asp. They also have a couple of other products. This is the same outfit that came in third in the lubricity test that some guy did over on the Diesel Place.com
Bruce
__________________
Bruce
__________________
I am thinking of switching to 2 stroke oil as well. But I have been getting good results from my 5 gallon pail of amsiol diesel fuel conditioner. Every fill up I add the recomended 1 : 640. The cost is very comparable, maybe even in favor of the amsoil. Will have to do some # crunching when my amsoil runs out in about 6 months!
I found this link and thought it was an interesting article, It from the diesel place forum
http://www.dieselplace.com/forum/sho...=fuel+additive
DOUG
p.s. I have been using Amsoil synthetic 2- stoke for snowmobiles at a 100/1 ratio. ????? It has to help, right?
DOUG
I was fortunate enough to speak at length with a Cummins engineer back in May. I asked him if it was harmful to run 2 stroke oil in the HPCR engines and he said he would DEFINITELY not add oil to the fuel. The engine is designed to run without additives. Take it FWIW, but you guys know there are a certain element of posters on message boards who want to be "Johnny on the spot" with some new miracle trick. Anyone who claims their mileage has gone way up and their truck runs better is suspect to me. You know what they say about something that sounds too good to be true.
colonialcobra
Jan 29, 2008 09:02 PM
JRAPTOR04
23
Oct 21, 2007 01:57 PM
