2 stroke or 4 stroke weed eater
Old Mar 13, 2011 | 03:02 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I finally,, after 16 years,I fried my 2 stroke 26CC weekeater...Was looking at the 4 stroke...30 CC..I need more power..
The 4 strokes are higher in price...Should I go with the 4 or stay with the two..
Old Mar 13, 2011 | 03:38 PM
Fronty Owner's Avatar
do you have any other two stroke engines?
If you need mix fuel anyway, I would go two stroke.
two stroke is typically lighter, but have to be run wide open to produce the power. for a weed eater, line speed is cutting speed.
Old Mar 13, 2011 | 04:22 PM
Bark's Avatar
I have a lot of area so for me, a good quality four stroke was the way to go. I have to adjust the valves and change the oil once a year but it only takes 10 minutes. Never fouled a plug or had any maint issues. Its quiter and uses less fuel. At the end of the season I dump the remaining fuel into the car and run it until it dies. Come spring it starts on the first pull. I think for a small area the two strokes are better.
Old Mar 13, 2011 | 06:18 PM
I run a saw in the winter and a weedeater in the summer. I regularly consume 2 stroke fuel. If my fuel starts getting old (late summer), dump it in the fronty and run. 3.5 ounces of oil wont matter in 20 gallons of unlead.
Old Mar 13, 2011 | 06:52 PM
Hvytrkmech's Avatar
I have an Echo 2 stroke straight shaft, it is a real animal, I only use it at 1/2 throttle.
Old Mar 13, 2011 | 07:17 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Stop messin' wit that namby-pamby stuff.
Get a REAL man's weedeater.
Old Mar 13, 2011 | 07:22 PM
jthorpe's Avatar
DTR Founder
I haven't seen this picture in quite a few years but it always makes me laugh when I do... LOL
Old Mar 13, 2011 | 09:39 PM
92'1stGen's Avatar
I have a Stihl BR600 backpack blower and a FS-90R trimmer. Both use different versions of the 4-Mix Stihl engine, which is a 4-stroke but it runs on a 2-stroke fuel mix. They are both very high torque engine's for there applications, and they run much quieter than the typical 2-stroker while consuming less fuel. My vote goes for the 4-stroke.
Old Mar 13, 2011 | 10:15 PM
Bark's Avatar
My old chainsaw fuel and 2cycle motorcycle fuel (both synth) go into the plow truck. I swear it fixed a carb problem and makes it run better.
Old Mar 14, 2011 | 08:46 AM
Dieseldude4x4's Avatar
She's a little hard to pull start but once you get her breathin, look out........
I love Stihl so I tried the 4 stroke eater, absolutely hated it. Turned the wrong direction, ate cord up faster than you could put it on even wire inserted cord, and still required 2 stroke gas. Had plenty of power though. I told them I wanted a weed eater that had a "GRIND STUMPS' setting on it and that is what they sold me. Took it back in two weeks and traded it on the smaller 2 stroke and never looked back.
Old Mar 14, 2011 | 04:02 PM
Bark's Avatar
Weird. The four strokes I have used did not require oil in gas.
EDIT: Did not know it but there are some newer hybrid 4-cycle engines that need the 50:1 mix. Gonna have to see how that works.
Never met a real sturdy trimmer that had the curved shaft.
Old Mar 14, 2011 | 05:10 PM
Clayten's Avatar
DTR's Toad Wrangler
Interesting, I always use a 50:1 mix on a four stroke first tank break in.
I have rebuilt numerous Harley's. I always had them bored tight. It just gave me that warm fuzzy feeling with the first tank mixed.
Old Mar 14, 2011 | 08:23 PM
Swamp_Donkey's Avatar
I have a Honda 4 stroke weed eater. Seems to work real nice for the last 5 years. I find that it does need a bit thinner trimming cord. Rpm's don't pick up in the heavy weeds with a thicker trimming cord.
04ctd
Jun 17, 2007 11:29 PM
mhuppertz
May 8, 2007 09:10 AM
vas
Feb 25, 2007 08:42 PM
scoggins
Feb 23, 2007 07:24 PM
JyRO
Jul 1, 2005 04:08 PM
