LP Question
Old Sep 2, 2008 | 09:03 AM
donnee's Avatar
LP Question
Im considering adding a Holly Blue or Red inline with the stock LP on my 05.
Question I have is if the stock LP goes out, will the Holly be able to get fuel without having to add a drawstraw?
Thanks.
Old Sep 2, 2008 | 09:36 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
Absolutely NOT. When my stock Lift Pump went out for the last time, I couldn't push a cupfull of diesel past it to the filter housing. After I changed it out and built my adapter bypass plate I could fill the filter housing in under 30 seconds!
If the stock LP goes out, the passage going past the rotor is super tiny and the pump usually freezes, vs just burns out the motor and will still turn.
Best advice... dump the Stock LP and go full Holley or aftermarket if you prefer.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
