13 Quarts?
Old Nov 23, 2005 | 08:46 PM
Stbentoak's Avatar
13 Quarts?
When I have changed my own oil I put in 3 gal of Delo and it only comes up to the lowest 25% of the crosshatches on my dipstick. I usually add 3/4 of a quart from a single bottle to get it full to the top of the xxxxx. Has anyone else had this issue? Should I just put in 12 qts and leave well enough alone?
Does that make sense?
Thanks
Old Nov 23, 2005 | 09:02 PM
rjm022's Avatar
takes 12 qts/3 gal. mine is exactly on the full mark. sounds stupid-but is your truck on level ground??
Old Nov 23, 2005 | 09:04 PM
timcasbolt's Avatar
Mine takes 12 qts. to fill it to the top including filter. After running the engine and checking for leaks, I have to leave it sit for 15-20 minutes to let the oil drain down into the pan or else it reads lower than it actually is.
Old Nov 23, 2005 | 09:16 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
Exactly 12 here, Dude!!!
Old Nov 23, 2005 | 09:32 PM
bulabula's Avatar
It takes a while for all the oil to settle down for an accurate reading. I pour in three gallons and not even think twice about it.
Old Nov 23, 2005 | 10:24 PM
Oilguy's Avatar
Stbentoak is right... I service about 30 or so 3rd gens and I have 2 of them that need 13 to show full.(after started and settled)(regular sized filter).. I don't know why but I just stick it in there so I don't get the phone call.
Oilguy
Old Nov 23, 2005 | 11:55 PM
IA_James's Avatar
Mine would read a quart low if it had been running any time recently, if it had set for at least 12 hours it reads normal. I think it's hiding it from me somewhere, trying to bait me into overfeeding it.
Old Nov 24, 2005 | 07:35 AM
Stbentoak's Avatar
The thing that tipped me off on this was I got a first free oil change at the dealer which I let them do.... when I got home and checked it,it was at the bottom of the crosshatches. I took it back and grouched at them that they didn't know what full was ! They swore they put 12 quarts in it,and I'll bet they actually did!
The 1st time I changed it myself it came up low with 12 and I thought I must be crazy...(Not to mention that it is hard to get single quarts of Delo around here)....
Now I just plan on 12-13 quarts to get where I need to be. And according to oil guy I must not be the only one......
Thanks for the info
Old Nov 24, 2005 | 08:06 AM
PourinDiesel's Avatar
If you drain it and put 12 in it your good to go.
Old Nov 24, 2005 | 08:11 AM
Stealth Mode's Avatar
12 or 13???
04 3500 HO 6 speed
i have always been puzzled by this also.. mine takes 3 gallons plus a little more to read FULL. i just changed over to AMSOIL.. and with the new filter "donaldson" ELF-7349 it read over full after 3 gallons and new filter????? the new filter is interesting. it has "spun" webbing inside with synthectic fibers to filter better.. i believe this new technology filter absorbs more oil??? or at least holds more?? so back on the lift and guessed as i cracked the plug and drained some out. then it said FULL? ok went home.. next morning read... 1/2 quart LOW?? go figure?? so at this point i would say i need 12 1/2 quarts to read full. i bet some trucks just are differn't...
ps: if i'm not mistaken...my manual says 11.5 us quarts??????? NOT
Old Nov 24, 2005 | 09:00 AM
TAS05CTD610's Avatar
13 Here
Well at least I'm not alone, mine is one that takes 13 quarts. Running a straipore filter I fill it with 13 quarts of rotella and it's on the full mark. Maybe it's something with the dipstick length or something??? 13 for me.
Old Nov 24, 2005 | 10:22 AM
Stbentoak's Avatar
Well Im glad there are others like me..... At least now I know I am not nutty or doing somthing wrong to the truck.
Old Nov 24, 2005 | 08:18 PM
doorguy's Avatar
mine takes 11.5 liters and right on the full mark.
Old Nov 25, 2005 | 10:01 AM
Oilguy's Avatar
I compared the dipstick lenth with the one on my truck and they are the same... But their truck definately takes 13 and my truck is 12 all of the 13's I have found are 04's >>> I find that a lot on other vehicles also... not just CTD's.
I use a digital metered gun so I know I didnt lose count with qts. >> That is the only way to go! hahaha
Oilguy
Old Nov 25, 2005 | 10:36 AM
4x4not's Avatar
Now don't go trying to confuse us Americans with your funny metric measurments!
