10 ply tire problems
Old Oct 22, 2009 | 03:29 AM
tcr's Avatar
tcr
Originally Posted by S/P G671
i put bfg's on mine,i hate them,truck wonders really bad,and tires started to wear funny,so i did everything in the front end and had it alighned.still the same.i want to get rid of the tires,what kind of tires are you guys using on duallies?i dont know what to get!!!!!!
Toyo ATs w/o a doubt. Will a 285/75/17 fit on a dually?
Old Oct 22, 2009 | 09:37 PM
Pikeman's Avatar
Mine does that with my 285 KM2's. Feel mushy at high speed manuvering. I am not impressed at all with these tires for many reasons. Everything is tight on my truck its just the tires...they suck. Have been shopping around for new tires but money is hard to come by for most these days.
Old Oct 23, 2009 | 11:30 AM
DirtEater's Avatar
Sounds like you got a tire that doesn't have a strong sidewall, like a Toyo E tire does.
Old Oct 26, 2009 | 02:47 PM
DBLR's Avatar
If seen some BFG''s that have 2 ply sidewalls way to soft for a 3/4 ton truck. BTW did you make sure they are E rated and not D's?
Old Oct 26, 2009 | 02:51 PM
.boB's Avatar
Originally Posted by richie waddell
not the ball joints have them all checked the only thing on the truck that is changed is the tires, it was like flipping a switch one day fine next all to hell,
There's the answer. If something changes after changing one thing, that one thing is the problem. If you want this problem to go away, bite the bullet and buy some new tires.
I know you don't want to, because you just spent a grand on them. But, after you spend the same amount of money changing a bunch of other stuff that's still good, you'll end up doing it anyway. Might as well do it now, and save a lot of frustration.
Old Oct 26, 2009 | 08:50 PM
Highway 4x4's Avatar
If you want it to handle the way it did, you've got to keep it the way it was.
Old Oct 26, 2009 | 09:09 PM
boyce's Avatar
New tires. Go to a parking lot and give it hell, sideways, front sidewall roll, etc. Found out long ago that new tires handle like **** for about 200-300 miles.
Old Oct 26, 2009 | 11:36 PM
Lost Lake's Avatar
If it's the tires, BFG will take them back.
BFG's aren't the best on these trucks, I know I've run them for 56,000 miles now. They have a soft sidewall. Well at least the 305/65R-17 tire... It needs a wider rim than the stock 8" to be right.
And tires that weren't rotated could have a heck of a pull, then you put on new flat tires and they let your truck go wild, exposing a problem you didn't know you had!
Old Oct 26, 2009 | 11:39 PM
annabelle's Avatar
BFG AT KO's....E rated......265's......no problems.
Old Oct 27, 2009 | 08:37 AM
Danderson's Avatar
Toyo and Bridgestone come with a thirty day waranty also.
Old Oct 27, 2009 | 08:41 AM
Danderson's Avatar
Neither Discount nor BFG would replace my 285-75-16's on my '98.5. I finally sold them on Craigslist and replaced them w/Toyo M-55's. Went from a D to an E,lost the vibes and gained a much better tire.
Old Oct 27, 2009 | 01:33 PM
annabelle's Avatar
So if you went from a D to an E you aren't comparing apples to apples.
Old Oct 27, 2009 | 03:47 PM
Danderson's Avatar
I guess the point I was trying to make was that neither Discount nor BFG would replace their hypo-vibe tires,one of which took 11 ozs. of lead to balance. Problems ended with the dismount of the BFG KO's and mounting of the Toyo product. Just didn't have a good experience with BFG to the tune of $800+.
Old Oct 27, 2009 | 04:10 PM
Lost Lake's Avatar
You guys that run the little tires probably have no problems with them. But I put the 305's on, and the stock rim is just too narrow!
I would seriously consider the 285 BFG in a 10 ply tire.
Old Oct 27, 2009 | 08:22 PM
annabelle's Avatar
You make a good point.........I have never had a balancing issue or death wobble or used excessive weight, but I have always run 265's.
sinawalli
78
Dec 29, 2013 07:51 AM
Ram95
18
Oct 3, 2010 01:28 AM
RAF
Mar 23, 2007 09:39 PM
Dickyboy`
Oct 14, 2005 09:59 PM
