1 piece driveshaft part number - 2004.5 quad 4x4 long bed
Old Apr 18, 2013 | 11:25 AM
nvr-enuf's Avatar
Looking for part number of 1 piece driveshaft and best place to buy
If anyone knows part number and place to buy the two piece rubber bearing carrier, I would like to know that as well.
Thanks
Scott
Old Apr 19, 2013 | 03:21 PM
JP-4.5's Avatar
All I can provide is the part number I purchased for my truck. This was from Doghousediesel quite awhile ago..
Looks like all they sell now is a custom shaft that is supposed to be better. but more $$...
1-52123220AB-1-Piece Aluminum Driveshaft for Automatic
495.00
This is part and cost I paid over 2 years ago. I was able to find sources by searching for this part number..
Best of luck.. You will like the single shaft. I had the 2 piece and could feel the difference when I did change over.
Old Apr 22, 2013 | 12:18 PM
nvr-enuf's Avatar
That part number is $905 at my local ram dealer - OUCH. She started rattling off a disclaimer about 2 pc versus 1 pc to address "shutter", etc - I never told her the year of my truck / if I even had a 2 piece drive shaft.
Old Apr 22, 2013 | 02:29 PM
JP-4.5's Avatar
I think the Doghouse diesel price is $7xx and is a larger/stronger one than the number I provided.
So the website states..
Old Apr 22, 2013 | 06:53 PM
Barefoot's Avatar
i have a one piece aluminum Ill trade for a 2 piece.
Old May 12, 2013 | 08:59 AM
horsehelper's Avatar
Steve White motors in NC is a power dealership and all there stock OEM parts are way cheaper then any local dealer. You can buy the new carrier bearing there for $124.00. My local dodge $209.00
Napa $180 Good luck
Old May 13, 2013 | 07:55 AM
jhenson's Avatar
Napa $180 Good luck
Or you can go to your local driveline shop and get a higher quality Spicer unit for around $60!!!!
Old Jun 26, 2013 | 09:33 PM
nvr-enuf's Avatar
part number?
Justin - Do you know the spicer part number?
I have my 2 piece at a local driveline shop to convert into a 1 pc but they are concerned it will not be robust / strong enough. They build steel driveshafts.
Thanks
SAS
Old Jun 27, 2013 | 08:04 AM
jhenson's Avatar
Thanks
SAS
Spicer P/N 210391-1X
Old Jun 27, 2013 | 05:06 PM
nvr-enuf's Avatar
Thanks - I decided to change out the carrier bearing and replace the bad u-joint as well as the remaining u-joint that has not been replaced yet
Old Jun 30, 2013 | 09:11 AM
nvr-enuf's Avatar
Carrier bearing replaced with equivalent to the spicer as well as replaced 2 of the 3 u-joints with the Spicer 1410 u-joints. I am sold so far on spicer vs precision u-joints.
Truck is really smooth, like new!
Old Jun 30, 2013 | 01:30 PM
labreck's Avatar
I got my dads 08 Vin # and went to the dealer and order the factory One piece. Had it shortened about an inch and a quarter, I forget exactly how much. $450 for the driveline $100.00 to have it shortened. It has been five years With no u joint problems
Stamey
Nov 22, 2012 09:01 PM
flyright
64
Feb 29, 2012 11:04 AM
Death Dealer
Feb 22, 2008 03:58 PM
Toto
Jul 26, 2005 09:30 PM
