'06 Jake questions
Old Oct 28, 2006 | 06:37 PM
hurricunning's Avatar
'06 Jake questions
Does the Jacobs Brake for an '06 spd use a belt driven vacuum pump? If so I assume the pump mounts on the driver's side of the motor taking up some space where I would want the Glacier fuel filter setup no? Anyone have any other comments about the Jake versus Pac or BD? I would rather have an electric pump. Do any of the brands have a superior flowing elbow or are they all pretty much the same thing. So far I am leaning towards going with the Jake only because it can be included in my factory warranty.
Old Oct 28, 2006 | 06:49 PM
iflych52's Avatar
I just had a pac brake put on my o6 and love it. Warms up the engine fast in the mornings and really slow the truck down. I have not towed yet. The brake is totally automatic. Once the engine temp gets up to about 175 it will turn off at idle. The brake will only turn on when the TC is locked up so the brake seems to shut off at about 22 mph. The pac works of compressed air. they include a quick disconnect air hose that you can plug into the compresser. You can also hook up your airbags with the installed tank. $1250 installed at my dealer. Hope that help. Aaron
Old Oct 29, 2006 | 07:48 AM
WING TRANSPORT's Avatar
Yes the Jac Brake does run off a belt. I had my dealer install one on mine and so far 8K mi I think it works well. I would do it again...
Old Oct 29, 2006 | 08:06 AM
Smokeman's Avatar
Glacier diesel has a different fitting to use with the jacobs brake as the vacuum pump is close to the cp3. I have the jacobs and purchased that particular one because of the warranty thing. So far so good, it helps warm the truck on cold days and works fantastic towing on grades. Good luck.
Old Oct 29, 2006 | 11:41 AM
rich's Avatar
i run the jake on both trucks wouldnt know what to do without it now
rustyshakelford
Jun 17, 2007 02:46 PM
Mexstan
Apr 2, 2006 09:44 PM
newtattoobob
43
Jun 12, 2003 11:13 AM
KenR
Jan 10, 2003 07:10 PM
Hunter
Nov 1, 2002 12:11 PM
