05 4x4 front end noise.
Old Jun 15, 2009 | 11:15 AM
creacy22's Avatar
I have had a noise in my front end for a couple of months now i first couldn't find anything loose or super apparent, but here the last week or so It has gotten worse so I jacked up the front end and checked for play on the top of the tire it seems normal, But there is a noise in the front left wheel when I turn it by hand now, and it seems to be in the same spot? That's the opposite of where i thought the noise was coming from.wheel bearing perhaps? thanks in advance you guys have always been pretty spot on.
Old Jun 15, 2009 | 09:51 PM
sticky's Avatar
I'm betting on front axle u-joints. Had mine replaced twice in only 80k miles.
Sticky
Old Jun 18, 2009 | 03:54 PM
creacy22's Avatar
probably so they look like a PITA... bummer
Old Jun 19, 2009 | 12:08 AM
BigIron70's Avatar
Cummins Guru
Grease the front trunnion. They do get noisy when dry, should be lubed at every oil change.
Change the engine oil filter.
Inspect the exhaust system.
Inspect the brake hoses.
Inspect the CV joints (if equipped) and front suspension components.
Check the automatic transmission fluid level.
Check the manual transmission fluid level.
Check the coolant level, hoses, and clamps.
Lubricate outer tie rod ends 2500/3500 (4X4) models only.
Lubricate Front Drive Shaft Fitting (2500/3500, 4X4).
JMZ
Dec 1, 2008 08:28 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
jetsnow
Sep 10, 2006 12:09 PM
Gordonville
Apr 18, 2005 09:45 AM
Mr. 45
14
Apr 25, 2003 06:22 PM
