Front end noise
Old Apr 22, 2003 | 08:51 PM
Mr. 45's Avatar
Front end noise
Went to Portland today and I noticed a weird noise I think it is coming from the left front tire area. Starts to make noise around 35 and seems to quite down a lot around 55 or 60. Sounds like a rubber bushing squealing, not metallic sounding What does a wheel bearing going out sound like? :'( If i stop for 5 minutes or so it won't do it until a little while later down the road Any idea's??
Old Apr 23, 2003 | 12:56 AM
Mr. 45's Avatar
Re:Front end noise
Got on the chat line and got some idea's. I think it is the front u-joints. When i turned it by hand i heard a squeking noise :'( I think this is it It's not a grinding noise! Gonna remove the front drive shaft and see if it still does it and if not, New u-joints for me 8)
Question? Does the front drive shaft turn when you drive in 2 wheel drive?
Old Apr 23, 2003 | 10:57 AM
emjay's Avatar
Re:Front end noise
I'm pretty sure the front driveshaft does not turn in 2WD, unless there's a problem with the CAD.<br><br>Sounds like you already found out what wheel bearing noise sounds like, but for the sake of the rest of the readers, it usually sounds like growling and/or grinding, getting worse with speed.
Old Apr 23, 2003 | 02:20 PM
Mr. 45's Avatar
Re:Front end noise
Well it's not the front drive shaft u-joint's :'( Removed it and it still does it. Balanced the front tires and checked air presure, Still same noise :'( I am thinking the u-joint in the axle shaft :-[ Hope it's not a wheel bearing &gt;
[move][glow=red, 2, 300]Any idea's???[/glow][/move]
Old Apr 23, 2003 | 08:06 PM
Mr. 45's Avatar
Re:Front end noise
[move][shadow=blue, 2, 300][glow=orange, 2, 3000]No taker's on this one???[/glow][/shadow][/move]
Old Apr 23, 2003 | 09:03 PM
Stamey's Avatar
Re:Front end noise
Where does the noise come from? Without the engine running you really should be able to pinpoint where the noise is coming from. You turned the yoke with the shaft out, right?<br><br>Chris (TORQUIN)
Old Apr 23, 2003 | 11:21 PM
Mr. 45's Avatar
Re:Front end noise
Try almost every thing that i can think off :'( I think it is a wheel bearing now, getting louder every time i drive it Had my brother drive beside me and he says it is the loudest at the left front side &gt; Will tear the hud down and see what the heck is going on!!!
Old Apr 23, 2003 | 11:25 PM
doomgaze's Avatar
Re:Front end noise
Does the noise stop when you put the brakes on?<br><br>Mine was making a similar noise, but when I pressed the brakes it would stop. Turns out I had to brake pads left and it was grinding into the rotors. To me, it should be just the opposite (makes noise when I brake and not when I'm driving), but thats what they told me.
Old Apr 23, 2003 | 11:29 PM
Mr. 45's Avatar
Re:Front end noise
Brakes on or off, slowing or speeding up, turning or going straight. In 4x4 or 4x2. All ways sounds the same. 20 to 60 mph i can hear it :'( Getting louder every second :'(
Old Apr 24, 2003 | 08:36 PM
Mr. 45's Avatar
Re:Front end noise
How hot do the front rotors get? Mine seem to be to hot to the touch! Burn your fingers if you keep them there long enugh Still can't find the problem :'(
Old Apr 24, 2003 | 10:43 PM
Stamey's Avatar
Re:Front end noise
Is there any way you can get it on a lift someplace, put it in 4x4 and drive, and lift it to listen for the problem area?<br><br>Alternatively:<br>Pull the left-front wheel. Compress the caliper so the pads are not touching the rotor. This can be done with a pry bar between the pad the the rotor. Be careful not to damage the pads themselves.<br>Once you have the rotor free of the pads, rotate it and wiggle it side to toside/up and down. There should be some play of the bearings are bad. If they are just dry there may not be any play, but if it is the bearings they should have some play in them by now, especially if it is getting louder.<br><br>You can also bit the bullet and pull the hub then split it to see what's up with the bearings. You'll need a 2 3/8 or 2 5/16 socket for the axle nut. I don't remember which.<br><br>If anyone else has any ideas, speak up.<br><br>Chris<br><br>
Old Apr 25, 2003 | 01:10 PM
Mr. 45's Avatar
Re:Front end noise
Well i have to get this fixed by monday the 28th I leave to go to work in Alaska 8) I am going to replace the front hub assembly and see if it stops ??? That has to be it $233.OO for the hub at NAPA If it still does it :'( I guess i will have a spare
Old Apr 25, 2003 | 05:37 PM
Mr. 45's Avatar
Re:Front end noise
It's fixed It's fixed It's fixed It's fixed It's fixed
I am so happy
Turned out to be the hud assembly
Cost me $233 for the hub from NAPA, $16.99 for the 1 and 11/16 socket from sears, and $19.99 for a 3/4 inch drive breaker bar! Tried to use my 1/2 inch breaker bar with a adapter Broke quicker that you know what ;D
Alaska here i come 8)
Old Apr 25, 2003 | 05:57 PM
Stamey's Avatar
Re:Front end noise
That's GREAT! ;D<br>Of course now you will be expected to help others diagnose, who post with a squeak. ;D<br><br>Chris
Old Apr 25, 2003 | 06:22 PM
dodgeman01's Avatar
Re:Front end noise
Mine just clicked for two years until I relized what it was. <br>DM01
jetsnow
Sep 10, 2006 12:09 PM
Gordonville
Apr 18, 2005 09:45 AM
Captain
Nov 5, 2004 11:46 AM
00turbo
Sep 19, 2004 08:32 PM
abb
Sep 23, 2003 10:46 AM
