bad front end noise
Old Sep 3, 2004 | 07:54 PM
00turbo's Avatar
bad front end noise
I was driving tonight when my truck started to make a loud sqeeking noise when i turn sharp both left and right. Has anyone experienced similar problems?
Old Sep 3, 2004 | 08:42 PM
nitrousn's Avatar
could be brakes? try to ride the brake and turn from side to side and see if the noise changes. could also be in a wheel bearing.
Old Sep 10, 2004 | 04:04 PM
ironman's Avatar
for some reason my brake backing plate was rubbing on the wheel at times when turning the wheel causing noise. I bent it out of the way and there has been no problem since. I put the truck on stands rotated the wheel by hand and was able to locate the source of the noise.
Old Sep 11, 2004 | 12:11 AM
upersleder's Avatar
mine did that last week all of a sudden, my inside pads were shot and the wear indicator was rubbing the rotor, i waited four days and ended up chewing one rotor for it. i did a quickie look at the pads this spring and all looked good, but i should have looked more careful as the inside pads wore down and he outside pads were over half way yet.
Old Sep 17, 2004 | 10:54 PM
Pa outlaw's Avatar
jack it up and check if the wheel isloose on the hub,a wheel bearing can make it do this cause the wheel is not flat in the bearing and makes it wobble a lil bit,thats where i would start if the brakes are fine,if the brakes look wore in a weird way check that bearing for it may be bad
Old Sep 19, 2004 | 08:32 PM
EricK's Avatar
I have the same problem,noise sounds like its just in front of the dash area.Happens when turning over 30 mph either right or left.Very annoying & I need to look the truck over soon to get rid of it.
greenrig
Apr 20, 2008 01:50 PM
greenrig
Apr 4, 2008 01:57 PM
jetsnow
Sep 10, 2006 12:09 PM
Gordonville
Apr 18, 2005 09:45 AM
C Pierce
Mar 21, 2005 08:41 AM
