NV5600 Oil Change Question
Old Jun 19, 2009 | 06:31 AM
Mark Hodowanec's Avatar
I'm changing the oil on my NV5600. I'll pull the bottom PTO cover bolt to drain the oil. When I put it back in, do I need to RTV it? If not, what seals the bolt so that the oil does not drip out? Also, 6 qts. or 5? 5 will get it to the top of the fill plug, but some say that an extra quart can be put in thru the top PTO bolt.
Old Jun 19, 2009 | 06:58 AM
Hvytrkmech's Avatar
Yes you should real the threads on the bolt. I have used hightack gasket sealant on pto's and tail shaft bolts in all my Internationals with great success. I have also used Loctite hvac joint compound which works extremely well but is harder to find. You can get the hightack at Auto Zone or Advanced in a smaller can for cheap money. Make sure you clean the threads on the bolt and clean the bolt hole on the tranny, also cover the entire thread surface with the high tack.
Isn't there a drain plug on you nv5600? That will be the lowest point.I had to pull the drain plug to get all the oil out of the tranny. I just pulled a pto off one of my carriers to do an overhaul on it, reassembled it and reinstalled it using the hightack on all the studs.
Here is a picture of the high tack.
http://www.jamestowndistributors.com...ct.do?pid=9400
Tim
Tim
Old Jun 19, 2009 | 07:05 AM
MikeyB's Avatar
I use regular old automotive black RTV. Hasn't been an issue.
The spec shows 4.75 qts I believe. I put 6 qts in through the top PTO bolt hole.
MikeyB
Old Jun 19, 2009 | 07:07 AM
98whitelightnin's Avatar
I also put in 6 qts and black rtv on the cover bolts with no problems.
blackdiesel
17
Jan 16, 2009 09:08 PM
ZacMan5712
13
Dec 24, 2008 08:31 AM
sandpuller2004
Oct 5, 2007 05:22 PM
supercharger
Feb 27, 2004 09:05 PM
bulabula
18
Oct 25, 2003 12:01 AM
