'04 hard start when warm
Old Nov 22, 2017 | 12:59 PM
allied12's Avatar
'04 5.9 always starts cold with a little cranking. Occasionally won't start when warm (after normal driving). I am guessing it could be a high pressure fuel problem as I have been told that electronics won't let engine start until it builds high fuel pressure on rail. Potential problems could be the high pressure limiting valve (relief valve) on the rail or an injector, not sealing and not letting the rail build pressure, but those I have talked with about the problem seem to think it should be worse on cold start if that was the problem. I replaced the fuel filter and the fuel lift pump and nothing changed. Otherwise truck runs great. 250+K miles. Let me know if anyone has had same problem or has other input. Thanks
Old Nov 22, 2017 | 03:33 PM
BigIron70's Avatar
Cummins Guru
Leaking injector, you can try capping each injector at rail one at a time until you find one causing no start. You need this capping tool.
https://www.handsontools.com/Miller-...UaAroHEALw_wcB
97Dually
May 18, 2006 10:47 AM
bboukari
14
Sep 10, 2005 09:17 AM
FamilyDiesel
Mar 24, 2005 07:12 PM
gaRam
16
May 8, 2004 11:09 AM
