Hard to start when warm
Old Mar 24, 2005 | 05:16 PM
FamilyDiesel's Avatar
If the truck is driven to town and shut off for over 15 minutes, but less that 2.5 hours it is sometimes hard to start. If it been off for a long time it always starts right up with just a blip of the key. The IP is also pretty loud(duh!), well maybe louder than normal, hard to tell. Does this sound like a lift pump problem? Or any other ideas. If its the lift pump, what is the least expensive way for me to make the repair myself? F.A.S.S. looks good but too much $$ for my budget right now.
Old Mar 24, 2005 | 05:23 PM
Geico266's Avatar
You should get a fuel pressure gauge right away and see what is happening. You can get a cheap one into the fuel filter canister just to see if it is working. If its low you may have burned up the IP already. If you have never replaced it, its gone.
Old Mar 24, 2005 | 07:05 PM
mini14's Avatar
usually an indication of a bad vp. starts great cold but not warm. has to do with the pumps ability to compress the thinner fuel when warmed.
Old Mar 24, 2005 | 07:12 PM
mini14's Avatar
u can bring it to cummins, they have a handheld pump tester that plugs directly into the vp's ecm. the old time test would be to pour cold water over the pump to cool it down, and if it starts right up then its a bad pump, but ive heard that u can run the risk of cracking the aluminum housing.
chop342
Jul 26, 2006 06:31 PM
97Dually
May 18, 2006 10:47 AM
bboukari
14
Sep 10, 2005 09:17 AM
gaRam
16
May 8, 2004 11:09 AM
