04 dodge 3500 stuck in limp mode
Old Sep 27, 2013 | 12:37 PM
dodgeman01's Avatar
My dads 04 decided to go into limp mode today. It was shifting fine yesterday but this morning it took off in one gear and won't shift. No codes or check engine lights. It's got 185k miles on it but never had any problems till today. I put a water pump and ac pump on it a few months ago.
Do you guys think its a sign of the tranny taking a crap or something else?
Thanks Aaron
Old Sep 27, 2013 | 02:02 PM
BigIron70's Avatar
Cummins Guru
Check the trans relay first make sure there is power and relay is working. Check the fuse also here is wiring may be of help.
Old Sep 27, 2013 | 09:36 PM
Spooler's Avatar
Sounds like a governor pressure solenoid and transducer needs to be replace. Take it out and shift it through the gears manually and see what happens.
Old Sep 29, 2013 | 02:03 PM
dodgeman01's Avatar
Thanks guys will try that
Old Oct 1, 2013 | 09:00 PM
dodgeman01's Avatar
Is there anyway to fix the 1212 back and forth shifts in the 48re? I've got 3 trucks and they all do it
Old Oct 2, 2013 | 01:26 PM
SOhappy's Avatar
We call that "shuttle shift". Upgraded BorgWarner governor pressure solenoid usually does the trick. Can be found for around $75 or less.
Old Oct 5, 2013 | 01:36 PM
driftingfly's Avatar
Might have the same issue here: Started slipping while in Tow/Haul mode coming out of 1st. Have to get heavy on the throttle and fan it to get it to shift into second. 2nd to 3rd is a little better and once in 3rd and O/D seems ok and holds. 178,000 miles on truck and transmission was serviced around 120,000 miles. Was told everything looked great then. Could this be a solenoid issue? How would I diagnose to tell if it is the solenoid?
Old Oct 5, 2013 | 01:38 PM
Might have the same issue here: Started slipping while in Tow/Haul mode coming out of 1st. Have to get heavy on the throttle and fan it to get it to shift into second. 2nd to 3rd is a little better and once in 3rd and O/D seems ok and holds. Truck has 178,000 miles on truck and transmission was serviced around 120,000 miles. Was told everything looked great then. Could this be a solenoid issue? How would I diagnose to tell if it is the solenoid?
Old Oct 5, 2013 | 01:48 PM
sorry for the double post
Old Oct 7, 2013 | 04:18 PM
If it does not manually shift into gear would it still be the governor pressure solenoid and transducer? Will it show a code on the scanner?
Old Oct 8, 2013 | 09:02 PM
My dads 04 decided to go into limp mode today. It was shifting fine yesterday but this morning it took off in one gear and won't shift. No codes or check engine lights. It's got 185k miles on it but never had any problems till today. I put a water pump and ac pump on it a few months ago. Do you guys think its a sign of the tranny taking a crap or something else? Thanks Aaron
dodgeman01 I hope your dad has better luck than I did. I had very similar symptoms and hoped for it to be the governor pressure solenoid and/or transducer governor sensor, but unfortunately it was the torque convertor and ultimately I am ending up spending $4k on a new HD transmission. Check the fluid, if it's burnt you'll have a good idea where to go from there. Best of luck!
JTBbudman
Aug 23, 2013 06:26 PM
missouriman
33
Sep 19, 2012 08:10 PM
OldSmokey
Mar 26, 2005 06:53 PM
arctic426
Feb 28, 2004 06:22 AM
danlit
14
Jan 20, 2003 06:55 AM
