Limp mode from high Pressure
Old Dec 2, 2002 | 07:52 PM
danlit's Avatar
Has anyones truck(24v) gone into Limp mode from to high of line pressure 140+ after a trans upgrade of TQ&amp; VB.<br> Danny
Old Dec 2, 2002 | 09:33 PM
TPilaske's Avatar
Re:Limp mode from high Pressure
Once, while Scott (MassDiesel) was test driving it. This was BEFORE the voltage regulator was installed. Haven't had any issues since! ;D<br><br>Tony
Old Dec 3, 2002 | 07:14 AM
hellotbone's Avatar
Yep a few times till I put a voltage regulator on it now no probs. Get one from DTT they are adjustable!
Old Dec 3, 2002 | 05:36 PM
BigBlue's Avatar
What about just turning the pressure screw in 1, maybe 2 turns? I want a little more holding power. My trans ain't slipping but I don't want it to start. Thanks.
Old Dec 4, 2002 | 07:06 AM
hellotbone's Avatar
Where do you make that adjustment blue inside the tranny or out I want a little more holding power too! also where you from you and I are the same age I believe.
Old Dec 5, 2002 | 07:07 PM
boehunter49's Avatar
???Hi guys hay what is this voltage regulator about I'm told that my trans is in limp mode now it has a code 1763 on the computer which is line pressure to high the trans was just redone with less than 1000 miles on it where soes this regulator go. Thanks Bob
Old Dec 6, 2002 | 06:17 AM
hellotbone's Avatar
Call up DTT and tell em what truck you have and that you want a voltage regulator they will send detailed color instructions. Its great!
Old Dec 6, 2002 | 10:37 AM
BigBlue's Avatar
Jamie, I'm in Houston, By God Texas and I'm 17. Anytime you get down this way, let me know. I'd love to see your truck.
You've got to drop the tranny pan in order to get to the scrwe. There are two screws down there. One adjusts the line pressure and the other adjusts the shift points.
Old Dec 6, 2002 | 05:57 PM
Jim Fulmer's Avatar
http://www.dieseltrans.com/phpBB/viewtopic.php?t=68<br><br>Follow the link!<br><br>Jim
Old Jan 18, 2003 | 11:54 AM
spassey's Avatar
install a 1/4 watt 150 ohs resister in pin 31 orange wire computer will be limited to how high pressure is because of resitence in wire will let it onlt see volts up to 4.0 volt
Old Jan 19, 2003 | 08:45 AM
admin's Avatar
[quote author=Jim Fulmer link=board=7;threadid=7798;start=0#76791 date=1039219044]<br>http://www.dieseltrans.com/phpBB/viewtopic.php?t=68<br><br>Follow the link!<br><br>Jim<br>[/quote]<br><br>The link is no good.
Old Jan 19, 2003 | 09:06 AM
CRobey4393's Avatar
is the 3.4 volts with key-on-eng-off? Or engine running?<br>Chuck
Old Jan 19, 2003 | 09:32 AM
spassey's Avatar
i believe it is a refrence voltage to the feed back sensor so its probably only being looke at during engine runnig
Old Jan 20, 2003 | 06:55 AM
hellotbone's Avatar
Just run the DTT regulator and you will have no probs.
Bobcat698
13
Aug 18, 2006 01:20 PM
tj97dodge
Jan 14, 2006 01:55 PM
swimmy
Dec 3, 2005 09:52 PM
OldSmokey
Mar 26, 2005 06:53 PM
arctic426
Feb 28, 2004 06:22 AM
