04.5 no start
Old Sep 19, 2009 | 09:07 PM
SUPRHLR's Avatar
04.5 no start
have an 04.5 truck that won't start, cranks but no start, scan tool says no communication. any ideas? where is the pcm located on these trucks?
Old Sep 20, 2009 | 07:57 AM
STate's Avatar
If it still has the stock lift pump, I would start there.
Old Sep 20, 2009 | 09:47 AM
SUPRHLR's Avatar
lift pump is in the tank, it will not cycle with key. I tried to bypass with jumper wire and can get the pump to work that way. I know this truck may need a recovery file, but need communication with the pcm first
Old Sep 20, 2009 | 10:23 AM
rich's Avatar
try using an alternative fuel source to try and see if it will start and run. the pcm i believe is on the drivers side on the motor next to the ecm
Old Sep 20, 2009 | 10:42 AM
SUPRHLR's Avatar
so is the pcm, ecm the same box on the side of the engine?
Old Sep 20, 2009 | 10:54 AM
rich's Avatar
no should be 2 boxes if i rember off my 03
Old Sep 20, 2009 | 01:22 PM
SUPRHLR's Avatar
I'm pretty sure there is just one module with 2 harnesses that plug into it
Old Sep 20, 2009 | 02:45 PM
eastmentCTD600's Avatar
Check your scan tool connection to the OBDII port. If you bent a pin (pretty hard to do but possible) you might get a com error. If everything at the OBDII looks good you may want to check the backplane and make sure everything is still connected.
CoolumConst
Oct 11, 2008 10:00 PM
bfarrell
Nov 30, 2005 03:23 PM
Erik Dlux
24
Dec 8, 2004 07:26 AM
502502
Nov 27, 2004 09:15 PM
eng208
Jul 14, 2004 06:21 PM
