03 wont start....what to do first
My basically stock 03 has been starting a little hard the past 2 weeks...nothing major, thought maybe the warmers were going....then tonight I went to leave work and it cranks but won't even kick a little.. nothing ...I just need to know where to start...by the way....165k, original everything...been a wonderful truck
I'd start with making sure my fuel wasn't jelled and checking my fuel pressure. Drain the fuel canister and then turn the key on- does it fill back up?
Are you still running the stock canister mounted fuel pump?
Sorry....once I plugged it in for a while , it started right up......as long as I keep it plugged in its fine....otherwise it wont start......it's only 25 degrees here....I never had a problem before.....any ideas?
Cummins Guru
I would start capping off injectors one at a time until I found injector causing the no start. Also check the batteries, low cranking rpm min 125 will not allow CP3 pump to build enough rail pressure.
Yeap, it is an injector issue causing a low rail pressure no start. Metal shrinks in the cold weather and return flow can go up causing a low rail pressure problem. The block heater keeps this from happening. Eventually, it won't start at all. Prepare for a expensive injector repair bill. You don't have long.
rustydeeretech
Jun 16, 2010 09:41 AM
Stroked-Z
Oct 4, 2008 11:28 AM
